tachograph:
Hope you don’t mind me jumping on this thread but I’m trying to understand where in the regulations it says that a reduced weekly rest doesn’t need to be compensated for if it’s only taken to end the 6x24 hour period
I can see how it makes good sense for it to be that way, but still it doesn’t seem to fit with the regulations as far as I can see
It fits perfectly with the regulations when you remember the regulations only require a driver to take one weekly rest period per fixed week and the regulations clearly state this.
In any two consecutive weeks a driver shall take at least:
– two regular weekly rest periods, or
– one regular weekly rest period and one reduced weekly
rest period of at least 24 hours.
Note the at least bit. You only have to do the minimum to meet the requirements of the regulations and the minimum in this case is one weekly rest period per fixed week. It’s all about reading and understanding the regulations and making sure the minimum requirements are met. The regulations don’t specifically say the second rest period in a week needs compensating for because they don’t need to, the one rest per week requirement shows that to be the case. If the extra rest period did require compensating the regulations would in fact have to state it, which they don’t.
So, in a week where a driver takes two weekly rest periods obviously only one of them is needed to meet the requirements of the regulations as two are more than the minimum requirement. Any additional weekly rest periods applying to the same week, be they reduced or regular, are surplus to minimum requirements be it because the driver took a day off or simply to prevent the driver working more than 6x24-hour periods without a weekly rest. In the case in this thread, by taking a full weekly rest period the the weekly rest requirements have been fulfilled for the week and therefore no compensation is required for the reduced rest.
If two reduced weekly rests are taken applying to a single fixed week then because the minimum requirements for the regulations is one weekly rest period, only one needs compensating for.
It is part of the same thing which allows a driver to take two consecutive reduced weekly rest periods in any two consecutive weeks, as long as at least one of the weeks also has a regular weekly rest applying to it. In that sort of case the second reduced weekly rest is usually only to prevent the driver working more than 6x24-hour periods. You will still hear many drivers wrongly claiming you can’t to back to back reduced weekly rests but you know this isn’t true.
Think of this scenario.
Week 1
Monday - resume work after regular weekly rest
Tuesday - Saturday work which brings upo 6x24 hour periods.
Sunday - reduced weekly rest.
Week 2
Monday and Tuesday work
Rest from 18:00 Tuesday - 06:00 Thursday which is long enough to be a reduced weekly rest.
Friday - work
Saturday and Sunday Regular weekly rest
Monday resume work.
Would you say the rest in the middle of week 2 required compensating for? It doesn’t.
It wasn’t there to prevent the driver working more than 6x24-hour periods, it was simply because the driver took a day off and a daily rest became long enough to become a weekly rest. He has met the requirements of the regulations by having at least one regular and one reduced weekly rest in any two week period. Reduced in week 1 and regular in week 2 so the extra one needs no compensation.
