danny_mk2:
I hope this is in the right place,
It wasn’t.
When you say your driving time resets to zero, I presume you are referring to an ancillary device such as Dynafleet, or a dashboard display? Whatever the visual display tells you, what really matters is what appears on your card. If in doubt, take print outs during the day.
Essentially, the display will operate according to which version of the driver software has been installed. There are (I think) moves to count the first 45 mins (15/30) of a P.O.A. as Break. Partly necessary because the second card position will not record a break whilst the vehicle is in motion.
Although this might sound sensible, I do a couple of runs where, after driving just under an hour, I have to wait another hour or so to get loaded. I then have a long run where, if traffic is bad, it will take me over the 4.5 hours, and not by just a bit.
The easy way was to put the vehicle on Break for 20 mins and then revert to POA. (Even though I wasn’t actually doing anything different - which makes a mockery of the concept in its entirety, but that is a different subject.
) That done, if I couldn’t reach my destination with the 4.5 hours total, I then only needed to take a 30 minute Break. One could argue that if I had taken a full 45 mins as Break when loading, then I could have reached my destination within the 4.5 hours but, as the final leg, which could be anything between 1 hour and 2 1/2 hours, with absolutely nowhere to pull off and stop, is so indeterminate, then I’m quite happy to stop where I know I can stop, when necessary.
Consequently, as a result of the software, I now need to switch to OW for a couple of minutes every so often, in order prevent the display registering that I have taken a full Break. Which I may well have done, but not wished the event to be recorded as such.
Madness or what?
