Ancona Repair Garage Needed for trailer
Hi,
Problem with trailer air valve on Frauhauf trailer, does anyone know of a non main dealer garage in the Ancona area, I would
run the vehicle into Volvo near the Airport, but the tractor units a Magnum ? and I do not what to call out Renault because there
charges are just so expensive.
Any help would be appreciated.
Regards
JJSL
Eurotrans used to run out of Cesana . They spoke English & were very helpfull . I used to work for 'em & they had all the kit & back-up contacts .They might be still going .Marco was the guv’nor at the time .Hope this helps .
I’d get yourself down to the industrial estate as your going in to Ancona port loads of small hauliers around that estate that could be of use to you.
Fly sheet
Many thanks, Guys.
Regards
JJSL
Just an update, a very helpful Iveco garage at Falconara just down the road from Ancona, pulled the wheel and
pushed back the “S” cam and refitted the slack adjuster and put a new Circlip on that had somehow gone missing !
Regards
JJSL
