Wondered if anyone can help, I get a new xf next month and mate has a 17 plate one, both ssc anyway we noticed on his under the holding bracket of the air suspension on drivers seat there is a hole and a connection inside, is there a possibility that is the connection for the duster gun, any info will be much appreciated, cheers.
On our 65-plate DAFs you had to splice into the air seat supply and fit a tee-piece.
I only know this as one of the drivers cut the supply then realised he’d got the wrong size connector
I don’t know if the connector is factory fitted in newer models.
I have one in mine. Love a good blow now and again.
Yeah my mate read about cutting into the seat supply too but there is a connection as I said so hoping that is for an air gun as does my head in now getting to the places with just a brush
My 66 plate xf has a plug at bottom of drivers seat just plug air gun into that works a treat.
Sent from my SM-G955F using Tapatalk
Pompeymark…is that the connection directly under the air suspension holder?
I have 16 plate and the connector is at the back of the seat by the base but it is a smaller fitting than the old ones
