Hi can anybody recommend a mini polisher that I can either run off the trucks air system or a battery powered one. Thanks in advance, Ben
Brooks81:
How small, as a Dremmel will easily run from an inverter, or any air polisher will run if the air tanks have pressure in them but you may need to run the engine and burn some diesel.
3 wheeler:
Brooks81:
Hi can anybody recommend a mini polisher that I can either run off the trucks air system or a battery powered one. Thanks in advance, BenHow small, as a Dremmel will easily run from an inverter, or any air polisher will run if the air tanks have pressure in them but you may need to run the engine and burn some diesel.
Just after running something to polish up the tanks etc I’m a lazy git
apparently, these are pretty good
ebay.co.uk/itm/SEALEY-GSA722 … 3a835fe2f1
but, you will need the engine running, as it uses the air pretty quickly
Only one thing I polish when i’m parked up!
happysack:
and, by all accounts, you use a magnifying glass to find it ![]()
shuttlespanker:
apparently, these are pretty goodebay.co.uk/itm/SEALEY-GSA722 … 3a835fe2f1
Cheers mate
I bought a 12v polisher this morning from halfords for £20 used it on the car today and seems great fir the money
shuttlespanker:
happysack:
Only one thing I polish when i’m parked up!and, by all accounts, you use a magnifying glass to find it
cannae deny that!
