Taken from a publication by Bendix in 1982 entitled “What’s Stopping You?”
SPRING BRAKE ACTUATORS
First used in America in 1956, they were introduced into the U.K. ten years later.
Described simply, they are a dual type actuator, the front or service portion working exactly in the same manner as a single diaphragm brake chamber. The rear portion (sometimes referred to as a ‘piggy back’ unit) is a cylinder containing a powerful coil spring, which is held compressed by introducing compressed air behind a piston or diaphragm.
Releasing the air will allow the spring to expand and this movement is used to actuate the secondary or parking brake.
And from the same booklet
TRAILER SYSTEM
The 3 line system (unique to the U.K.) has been in use for nearly 20 years.
In this, and the newer 2 line system, the service brake has its own reservoir, charged through the Emergency (Supply) Line.
RELAY EMERGENCY VALVES
The control centre of this system is the relay emergency valve. As its name implies, it performs two functions.
During normal service brake applications it operates exactly as a relay valve. It delivers air in volume from the trailer reservoir to the actuator, exactly as signalled from the towing vehicle via the service line.
Should the emergency (supply) line fail, for any reason, that pressure drop will cause the emergency portion to deliver full reservoir pressure to the trailer actuators.
Whilst the last sentence may seem confusing, consider that is was written in the days of Single, Double and Triple diaphragm chambers (and Lock Actuators, which I’ve never seen) before Spring Brakes became commonplace.
The main point to consider is that the Service (Yellow) Line merely transmits a ‘signal’ to the RE6 (or whatever number it is up to nowadays), which controls the air flowing between the trailer reservoir and the brake chambers.
The reason that it is done this way is because if ALL of the air required to activate the trailer brakes, had to pass from the Unit, and along the Service Line and its associated pipe work, then there would be a significant delay between the brake pedal being pressed and the trailer brakes operating.
Technically, the Service Line could be replaced by an electrical voltage, or a digitised signal, passed either through a wire or a radio link to the RE6.
