AEC V8
Great thread this. I love tales of derring-do by designers and engineers, even though this story had a sad ending. I did not want to post my thoughts/questions about the AEC V8 until I had read the book, a copy of which I now have (Thanks very much Gingerfold. Please contact me re payment).
Rather than lacking a few finishing touches of development, it appears, to this old curmudgeon at least, that the engine was ill-conceived from the outset (Anorak off, flak jacket on). It was a short-stroke, high-revving screamer, with such an engine’s typically low peak torque (not to mention concerns about fuel consumption and durability associated with engines of this type). I had initially assumed that this must be due to the influence of Leyland- having made their otherwise wonderful Ergomatic cab about a foot or more too small in every dimension, they needed a compact engine to power the new breed of motorway-oriented vehicles, that they and everyone else in Europe were developing. I was surprised, therefore, to read that the initial (prior to the merger) design brief was “for a compact power unit able to produce 250 BHP.” It was launched as a 12.1 litre to compete in this new market sector, while most of the competition introduced engines of 14-16 litres capacity, producing 300-350 BHP.
Other details mentioned in this thread and the book include narrow crank bearings, inadequate water pump, restricted coolant channels in the cylinder block, low coolant flow rate and suspect governor (was this at least partly responsible for the engine’s reputation for great performance, and some of its durability/overheating issues? A poster above mentions 4500 RPM!) . I bet that, in keeping with the “compact” theme, it had a really short conn rod, one effect of which is increased piston side load (causing more friction and heat) and higher big end load. Does anyone have any drawings or dimensions, so I may check this against comparable engines?
To make the engine more competitive on power and torque, it would have wanted an increase in stroke to give about 15litres (Berliet solved the problems with their new-in-1970 12.8 litre V8 by, amongst other things, enlarging it to that capacity. forum.aceboard.fr/12980-1221-277 … -TR300.htm). This would probably have entailed a larger crankcase and, certainly, a taller cylinder block. Make it tall enough to accommodate longer conn rods while you’re at it please, just for me! The cooling issue would have meant a redesign of the coolant channels in the block. To cure the big end wear problem- longer bearings, entailing a longer crankshaft, therefore increased bore spacing, forcing new cylinder head castings. In other words, the thick end of a new design, at far greater cost than a bit of detail development.
How would the proposed 350BHP turbocharged version have fared, with another 30% more heat to dump into the coolant? The obvious solution to all the above was to turbocharge the AV760 and leave the “supertruck” end of the market to the competition, in the absence of sufficient time and money to take them on properly.
Maybe the “small package” part of the engine’s design brief was due to Leyland’s influence after all- the project started in 1961, the takeover was in 1962 and the Ergo may well have been tooled up, ready for its launch in 1963. If the “merger” was in its “courting” phase at the start of the work, the board of AEC may have felt the need to make the company more attractive to Leyland, for the benefit of their own shareholders, hence an Ergo-friendly specification for the engine. Who knows?
The V8 proplems were apparently solved and the engine was ready for relaunch in73 but those great men from a little town in Lancashire stopped it , :laughing: does anyone know how they solved the problems and did any of the engines get released and did they have them on test with any hauliers.....theres a few questions i`m outta breath now
Hi, About 5 years ago i used to deliver methanol to Caberboard in Cowie. When we were offloading there was a shed right next to us where tippers used to bring in urea.The company was Cessford of Brechin. One of the drivers was called Andy and he used to tell me he was given one of the first V8s in a mandator to drive to the middle east. He said it went through 2 engines on the way over and had to be towed back to dover, He said as the lorry was on a trial run Leyland picked up the cost.(Andy could tell some stories so i don’t know if he was telling porkies) He said it was a great motor to drive, maybe someone will know Andy and ask him. He said Scania had something to do with this trial run, Again only Andy knows (this was his first run after passing his test so maybe no truth in this story)
matt watson:
There`s no truth in the V8 Scania being the V8 AEC engine reworked
It would have been great for British lorry-building if they had found a clever fix (or, more accurately, fixes) for the V8’s problems but, by 1973 Leyland had the TL12 at 280-odd BHP, so why go to the trouble/expense? It would have been greater still if they had somehow developed the mooted 350 BHP turbocharged version to perfection but, if this was so, Leyland surely would have jumped at the chance to use it, rather than kill it off. I would be interested to know what improvements the engineers tried though.
My posts might sound like typically negative Brit-bashing, but they are not- I think the efforts the British makers made in the 70s and 80s to drag our lorry industry back to prominence were, in the main, quite heroic, given the small market share they had across the Continent by this time.
The V8 was reliable in the right hands. If the driver and maintenance were just right, it would run quite happily in a fleet. As I have said before, Boon Bros worked their V8 very hard, and although it needed twice the maintenance of the Mandator 760’s they kept going with it until 1978. It had regular drivers who loved it, and regular engine exchanges, but gave them no major problems in service alongside thier TL12 Marathon’s and Mandator 760’s.
The biggest problem was knocking the bottom off it’s radiator in ruts in the LBC brick yards.
ERF:
Was this the longest running V8 on regular work ? ,my dad always reckoned that because they could go a bit drivers made `em go ,he agreed with you in saying if they were driven properly they would have been less troublesome, but he never drove 1
ramone:
ERF:
It was almost certainly the longest running V8 on regular ‘hard’ haulage work.
All the examples from the large fleets had been withdrawn by 1974/75, with most going back to the AEC works for disposal via a British Leyland contracted scrap merchant, but some from Alcan and the RTITB were converted for further occasional work as breakdown trucks.
Some smaller operators kept the V8’s employed as local ‘shunters’, and one or two owner drivers kept theirs running until major failure deemed them uneconomic to repair.
ERF:
ramone:
ERF:
74-75 wasnt that around the time AEC had sorted out the problems but Leyland wouldnt relaunch it? i think the AV506 turbo was about ready then too but …
Does the cab look different on this V8 or is it me ?
ramone:
I believe it was termed/called the “High Datum” cab “ramone” Cheers Dennis.
ramone:
I thought that was exclusive to the Leyland range i didn`t think AEC fitted them
ramone:
ramone:
AEC were part of “the Leyland” range when the Ergo cab was produced “ramone” Dennis.
ramone:
ramone:
I know AEC fitted the ergo but i didnt know they ever fitted the high datum version which i think was first fitted to the Buffallo around 71 - 72,i could be wrong Dennis im much younger than you so i will stand to be corrected by an elder much more experienced man :wink: :wink:
ramone:
ramone:
ramone:
Don’t give me all that “soft soap” ramone—it won’t wash! wink! I always thought that AEC had to use the High Datum cab on the V8 chassis? Cheers Dennis.
There’s a bit about the High Datum cab on page 4, only around 40 were built but not sure how many of these were Mandator and the Mammoth Major six wheel tractor unit which also had the cab, mainly for export. The normal cab was fitted from the beginning to the V8 Mandator, maybe if the High Datum idea had been used from the introduction the overheating problems wouldn’t have occured, however it seems it was that problem that spawned the higher cab.
Franky.
Ahh just read again what I’d posted on page 4 and approx Twenty Majors with the High cab were built so around the same must have been Mandators, obviously Leyland pinned their hopes on the 500 engine and high cab with the Buffalo making better sales than the V8 Mandator but we know how badly that went too!
A Essex company, Westrope Bros had a V8 Mandator LEB400G, when I first worked there in late 1973, the engine was out of the truck and apart on the workshop floor, cant remember what the problem was or who put it back together, I had just started as a mechanic then, all I can remember when it was running, it suffered with engine oil leaks. It use to run to Arbroath Scotland, can also remember the drivers name, but he has sadly passed on now, his roping & sheeting was second to none.
When I passed my HGV test, I did have the good fortune to drive the truck, if it was in the yard when they wanted a trailer loaded, it was a real flyer and really pulled well. Where is it now?, rumoured it spent its last days in Arbroath.
There’s a few Park Royal
As I wrote elsewhere, something I came across while browsing flickr recently:
Imgur
Imgur
Imgur
Apparently an AEC V8 with a double-bunk high-roof sleeper cab @ramone
