newmercman:
Do you think the use of dry liners was an attempt to overcome the heat issues that were obvious from the start, wet liners in an engine that was obviously going to run hot would succumb to cavitation and kill the engine long before any of the other shortcomings surfaced.
Also was the cooling system pressurised to raise the boiling point? Were there less cooling system problems during winter when anti freeze was used, therefore raising the boiling point?
Purely hypothetical I know, but I’m sure that using up to date materials, oil and coolant, the V8 could be built today to the exact same design and be as reliable as anything else available.
50yrs ahead of its time perhaps…
There is no doubt in my mind that AEC used dry liners purely for reasons of block stiffness. They had moved away from wet liner in line engine designs some years earlier due (if I recall correctly) to head gasket failure issues caused by fretting between the block and head, which was put down to the block flexing.
AEC went to great lengths to stiffen up the V8 block, including using fully fitted cross bolted main bearing caps, so they could obviously see a potential problem there. I have been trying to get a grip on ‘[zb] anorak’s proposal a couple of posts back, which could be an entirely valid point, but without knowing where the existing stress points are, it’s difficult to reach a conclusion. The AEC V8 block as it was produced was successful, in that I don’t know of any fatigue cracking at all. The head gasket issues that the AV740 suffered with were down to how the fire ring sealed around protruding liners, not block to head joint fretting.
Wet liner (or even parent bore cylinder wall) cavitation errosion can orrur whatever temperature the engine runs at. I know of some horrendous problems with old Ford Diesel engines where cavitation had erroded right through the cast iron cylinder walls. Also ■■■■■■■ of course. I have had several NT855’s over the years with failed liners, even (allegedly!) with the DCA additive at the correct strength. I remember Shotts issuing several service bulletins about it, including changing the cheminal composition of the DCA itself at one point. These days I don’t use DCA in that form at all in ■■■■■■■ engines. After listening to a lot of recent research on the subject, I now fit a plain long life coolant filter with no DCA dose, and use a well tested long life ready mixed coolant with the modern inhibitors built in, such as developed by Caterpillar, Volvo Penta, Perkins and ■■■■■■■ themselves, and then change it every five years.
There is a bit about it here from Cat…
cat.com/en_US/by-industry/m … iners.html
Getting back to the AEC V8, it runs with a very low coolant pressure of just 4 psi, which I have always felt was very low, and perhaps contributed to the localised boiling issues that the engine suffered with.
Modern coolants and oils far out perform those available 50 years ago, and there is no doubt that the AEC V8 engine will benefit immediately from them. I’m certainly hoping so anyway!.
