It isn’t possible to redesign an engine in a couple of hours even these days, so let’s not get too ■■■■■■■ in the minute details, but running all the figures through today’s design technology was an interesting if pointless exercise, especially in light of ‘gingerfold’s latest post.
I asked them to run the basic calculations based on a slightly ambitious maximum design output of a reliable 450 bhp (projected 100’000 mile overhaul in line with Perkins engines of the day - AEC usually substantially exceeded this).
All the initial AEC V8 design constraints had to be observed, so the outside width and hight dimensions of the engine remained unchanged. The AV801 bore dimension of 135 mm remained with the 114 mm stroke, with turbo charging applied. As far as was practicable, the calculations were based on the recommended oil specification available in 1968, and the Glacier ‘SB’ bearing material used for the later production run (the ‘SC’ material was developed post production).
The valve lift, inlet and exhaust valve head sizes and connecting rod cross section were all found to be satisfactory, as were (surprisingly) the main bearing journals of 95.184 mm diameter and 43.70 mm (front), 56.00 mm (rear), 47.65 mm (centre) and 47.72 mm (intermediate). This gives a combined projected bearing area of 235 sq.cm. Adequate.
The original big ends were inadequate by some margin because the calculated oil film pressures developed on the bearing surface were excessive. The original design used a crankpin diameter of 88.9 mm with a bearing shell width of 28.5 mm. The minimum requirement for the proposed power needs an increase in area of 21%, which keeping the 88.9 diameter could be achieved with a width increase of 6.2 mm per bearing. This would take the combined projected bearing area upto 247 sq.cm, just 2 sq.cm over the absolute minimum calculated requirement. This would require a crankshaft 49.6 mm longer than the original.
Obviously a longer crankshaft requires a longer cylinder block, heads and all the ancillary components. A 50 mm longer block would allow a 16.5 mm increase in the cylinder spacings - and according to the information available, that would be enough to improve coolant circulation dramatically. Just visually judging the thickness of the block cylinder wall (from photos of the sectioned engine), and the block deck coolant passages, they suggested that there looks to be slightly too much material present. An experienced eye suggested that 5% could safely be removed from this area, further opening up the coolant passages. We did discuss the AV740 engine and it’s 2.5 mm thicker block cylinder walls (on the piston side, of course), and the consensus was that at full load, with the pistons being so short, they probably would not be able to transfer enough heat through that thickness of iron into the coolant.
But then we knew that!.
The pistons of the AV801 at it’s original rated capacity and design would be able to transfer enough heat, but teeth were sucked when turbo chargers and increased BMEP’s were mentioned. The theoretical 5% material reduction was considered enough with the improved coolant circulation of the extra block length and cylinder spacing to comfortably allow enough actual heat transfer to take place. All theory of course.
But the pistons are another matter. They say there is no way that the original design of piston could possibly operate at 450 bhp to be reliable in service. Oil galleries cut into underside of the piston crown and piston cooling oil jets would help, but they still said that in 1968 the aluminium piston capable of handling the proposed power at the original piston dimensions was probably not available. Composite pistons, or special lightweight cast iron pistons were a possibly, but hugely expensive back in the 1960’s.
It is interesting to note these findings, and does demonstrate just how very close Keith Roberts and his team came to developing a successful engine. I was perhaps a bit ambitious proposing 450 bhp, 350 bhp was the figure that the AV810 engines were tested at, but I think the conclusions are interesting all the same.
