I am still under the impression that EBS and ABS are a safety feature but are not the main force of braking, only a control module.
VOSA agree with me and they suggest this:
Where a braking system is primarily operated by air, although incorporating an electronic control system e.g. ABS or EBS, the system is considered to be an Air system.
A hydraulic system is one that is primarily hydraulic and may be air or vacuum assisted.
An electric brake is one where the foundation brake is operated solely by electrical energy.
Kind of but no, as I (wrongly) put on another thread, modern brakes work much better and quicker because they’re actually electrical valves, so when you brake it sends an electrical signal to activate the brakes, and can also turn 1 brake on or off, so when locking, it won’t release all brakes, only the locked one(s).
BUT…
cieranc:
I can’t think off the top of my head what system CF’s use (wabco, knorr bremske, haldex + maybe midland grau are the only ones really in use these days), but when I did my Haldex factory course, this was discussed. They said that in the event of any electrical failure or malfunction, the system would ‘fail safe’ and operate as a pure mechanical/air system, as this was a mandatory requirement for type approval purposes.
So… if the EBS ECU lost it’s power and the brakes failed to work, then it ain’t meeting the conditions of it’s type approval.
On the most part this is neither here nor there, but in the event of a fatal accident, if the inquest finds that them brakes not working contributed to the fatality, then someone somewhere will be finding out exactly how the corporate manslaughter laws work
This is also true, any lights on the dash should DISABLE the function and return to normal braking, so an abs or ebs fault should return to normal braking ie pure hydraulic and pumping if locked.
This is no different than the abs on your car, if the lights on, you can lock your wheels but your brakes work fine.
