Has the bridge on the road the comes from dunchurch/rugby been re-classified to 12’6 again
I ask i went past a warning sign for the bridge on a roundabout near dunchurch the other day on my de-tour to avoid the bridge by truck was 12’4 and i notice the sign said 12’6 but i could of sworn it used to say 12’3 after it was changed from 12’6 originally.
can any stobart/tesco drivers shed any light on this, as if thats the case i can now ram my truck under it and avoid a de-tour from crick to dunchurch.
It is marked up as 12’ 6, you are correct…but I can tell you that mine runs under it at 12’8 The reason I know is cos I wear BRIGHT ORANGE RAIL GEAR!!!..
PLEASE NOTE: I WILL NOT TAKE RESPONSIBILITY IF YOU HIT IT!!!
shade:
it’s higher than 12’ 6" , that’s all i’m sayin BUT has been signed as 12’ 3 “AND” 12’6 " in the past
I’ll ditto Clarkys comment about [zb] it tho !!
PMSL…see what am saying
I REPEAT I WILL NOT BE RESPONSIBLE IF SOMEONE TAKES A SHOT AT IT AND SMASHES IT!!!
(Just remember to ring the rail police to let them know ok!! )
i’ve not been in that area since my post, is their option to turn round near the bridge should i decided i wont fit under it, so your saying a 12’6 truck will comfortably drive under it, is it arched:?:
Yes it is arched and set at an angle , as for turning round , if your coming from Rugby I suppose you could reverse back to the pub turning (Old Royal Oak) but if your coming from Crick you’ll stuggle . Many moons ago I used to work at Tossco Crick and quite a few trailers ended up with sunroofs going that way Becuase the bridge is at an angle and arched you have to come thru at the right angle or
shade:
My advice…if in doubt…
If you’re coming from Crick isn’t there a small trackway into a yard that holds some sort of railway gumf, on the right that you can back into?
I can confirm that a NFT reefer trailer will go under it , both ways
There is a bridge in Chepstow marked 11.6 but I have been under it with a container, it was a standard container and I had to dump all my air tractor and trailer but it does go under…Just…
