Hi,
As you can see I am also new to this forum but not entirely new to Road Transport and also an operator and O Licence holder.
Having something of an interest in Military Vehicles of the Truck variety your post took my interest and will try to offer some friendly advice to you.
Firstly, if you are looking to buy a low loader, take it a unit and trailer is what you have in mind, and also use it for general haulage when not in use carting the 432 about then you may face a couple of problems that will need further research on your part.
Operators Licence will be your first obstacle: 2 routes you can take on this
A/ Take your CPC, Certificate of Professional Competence, apply for the operators licence in your own name as Transport Manager, fulfil the requirements of the Traffic Commissioners including financial standing, good repute, operating centre, Maintenance facilities etc.
A whole list of the forms and publications can be found here
dft.gov.uk/vosa/forms/lorryo … gforms.htm
With some further interesting and informative stuff here
businesslink.gov.uk/bdotg/ac … 1074407470
B/ Employ a CPC holder / Transport manager or company that specialises in these matters and still have to fulfil the above mentioned requirements apart from actually holding the CPC yourself.
It’s a lot of hard work but if you are sure that you want to go that route it is worth it.
Second is your experience and length of holding a licence to drive.
Insurance for Low Loader work can be quite steep due to the value of the loads being carried and the possible problems that they can cause, abnormal weights and sizes to name just two.
Obviously your insurance premium will be in some way linked to your experience and track record…
Depending on the weight of the 432, somewhere in the region of 15 tonnes I believe you would not need a huge outfit to haul it but going small in the world of low loader work is not really the way forward so you would be most likely be looking at 44 gross at the very least.
If you are determined, can get insurance, find work, which is not bountiful in the low loader market at the moment, then I would say you will be unlikely to look back and will be able to cart the 432 about as well.
If you doubt you can do the above then I would suggest the following.
Find yourself a Historic vehicle, Scammell maybe, (I am biased, I have 2 of them!) either tractor unit and low loader or Truck and trailer and move it about that way.
Best of two worlds then and two vehicles to show at the rallies etc.
Or get someone to move it for you, its not as expensive as you might think
You might want to take a look on the HMV forum hmvf.co.uk/ These guys are moving stuff about like this all the time.
Good luck
