8.25 - v - 9.00 inch wide rims
Any advantage on going wider rims on the steer axle for 295 section tyres?
only ever used 9 inch rims for 315’s myself
what made you think about putting 295’s on 9inch rims?
moose
Moose:
moose
Seen some on fleabay, a google search says they can be used with 295’s but was wondering if there was any + or - points.
295 should only be on 8.25
305 can be used on either
315 for 9.
Saying that i have some 315/70 on 8.25 alloys that run nicely.
No Advantage.9 " rims on 295s dont fit correctly for some strange reason?? something to do with the tyre width
I’ve ran 315’s on 8.25 rims they looked OK if a little fat, doing it the other way I think would be worrysome as the tread pattern would be narrower than the rim…
fly sheet:
You can put 315"s on to 8,25 rims but it doesnt work the other way round 9.00" on to 295"s to much pull on the tyres?
globby 480:
fly sheet:
Yes Chap thats what I’m saying in My own way :slight_smile:
According to some blurb I’ve read you can put 295’s on 9 inchers, but I think I’ll stick to 8.25’s and keep it simple :grimacing:
