24 volt cables/Anderson connectors ready made up
Hello, sorry if this has been posted here before but here goes;
I have a 24 volt microwave and want it working in my cab, obviously!
I won’t bore you with the details but I need the following making up for me because I’m about as mechanical as a hat.
1 x length of cables - battery terminals on one end, Anderson connector on the other. Anderson end to have waterproof cap and bracket to fix to catwalk.
1 x length of cables with Anderson connectors on both ends with an in-line fuse.
The above to be made up/soldered etc.
1 x Anderson connector to attach to the cables from my microwave (I think with some cajoling our fitter MAY solder this bit for me…).
Do any of you know of any companies that would carry out this sort of work please?
I will of course supply any companies with lengths/diameters of cables required etc.
Many thanks in advance.
Quite a few come up on googlyarse search - Torberry.co.uk might help
Thanks dchpx,
I have just sent them an email.
Thanks again.
I reckon any local Auto Elec outfit would sort you out mate.
I got a similar set up built, and it was about a tenner plus parts.
