Gear lever feels like its waving around mid air, I’ve had the cab up and down a few times but always ensured it was in neutral. However it popped out while the cab is down and no amount of re-seating and moving the stick about as per the instructions is clipping it back in.
And hints or places I should look for something which has failed? Looks to be all still connected when the cab is up.
If you have a 5 speed box ,have you broken the gearbox turret ■■? Generally happens then the gearlinkage doesn’t delatch,and the cab won’t tilt until you pump it like a man possessed then bang it tilts at the expense of the turret
