18plate daf heater
Does anyone know if you can dim the display on the heater panel at night
With the ignition off and the night heater on the heater panel is lit up like a Christmas tree the same can also be said of the temp display on the bunk wall I have to bend the reading lamp over to cover the glare
I wear sun glases,find they do the job
Robbo919:
Should be a diimmer switch there somewhere.Can’t remember where it isof top of my head.I’m not in the cab at the mo.
I’ve tried the dash dimmer switch it makes no difference
