Does anyone know if a 12volt 1500 watt inverter will run a 700 watt microwave
Y woud you want to run an inverter to another inverter
bigdave1:
Maybe just, but i’m guessing really. As far as i know the 700 watts of the microwave relates to its output and not whats needed to run it.
Just about, but a 2kw inverter would be better.
A typical microwave oven rated at 700W output will draw something like 1200W from whatever power source it is using (be it mains, inverter or generator). So it should be OK with a 1500W inverter. Best to check the specs of the oven you intend to use though.
just to ask a question while this topic on the go …
will a 30OW inverter run from the 12volt power socker be ok to power a laptop maybe a cooler box ■■?
pump:
just to ask a question while this topic on the go …will a 30OW inverter run from the 12volt power socker be ok to power a laptop maybe a cooler box ■■?
Yea, fine to run both, lappy will be about 150w, cooler will be about 70w.
thought a cooler box would be a lot more
pump:
Well, here’s a 12v 40 litre coolbox from Halfords and it’s rated at 47 watts.
But there will be a sticker on it somewhere telling you the wattage.
Harry Monk:
pump:
thought a cooler box would be a lot moreWell, here’s a 12v 40 litre coolbox from Halfords and it’s rated at 47 watts.
get you now … thanks for the help
