albion1971:
Cheapen the job? It’s a lorry drivers job transporting cars etc. instead of other goods for gods sake.
I never said it was easy. No job is till you learn it but like any other you are given training and then it is down to the individual to learn and practice.
A bit like driver training and we all know what that produces!
It ain’t rocket science and as I said anyone with average intelligence can do the job if they desire that type of work.
Some may not think it is worth all the hassle. Each to their own as they say.
That’s quite right, anyone can do the job, but in practice the drop out rate during just after or within a few weeks or months of training is or used to be very high.
Where i worked for the first 5 or 6 years it was probably 20/40% retained rate after 12 months at one time, when i managed to get onto one of the best operators the drop out rate fell dramatically, BUT, the vast majority of new drivers were, like me, already experienced and doing exactly what they had planned all along, getting a premium job after learning the job inside out (and getting the start nod, you didn’t start out on those jobs unless you had family there)
What i wouldn’t like to see is someone who has a decent job already go for one of these in the belief that it’s going to be exactly right for them…however as i said before, being hourly paid takes a lot of pressure off the new driver.
The other point i want to make is that learning the job in years gone by had some complications, if you got an artic it would have a peak over the cab, that was ‘‘interesting’’
and yes i had one for several years, but the bodies were simpler overall, the three deck artic body being the very best, circa 20 mins to load or unload including strapping down once up to speed.
Now with the +11’s and EHR bodies, and whatever else is now out since i packed it in, carrying 11 cars, maybe 12 with a few small ones, but less if a mixture of cars 4x4’s and vans, the new driver is going into a baptism of fire, there is a hell of a lot to learn.
I’m not sure i could have coped with going straight on to a +11, it was a big enough shock to the system getting one when i’d been doing the job well over 10 years already, i hated the thing (didn’t help that it handled like a plate of spaguetti in the dry) it took me at least 12 months before i became relatively happy with it and probably another 12 months before i could just look at a mixed load of vehicles sitting on the ground and know instinctively where they were going on the lorry but i’m probably a thicko, remember its reverse drop order preferably and best if you know your delivery area because there might be trees and low bridges mixed in that journey, some you can’t pass fully loaded but you might after losing half the load so getting it to a ‘‘flat’’ load.
Some of the blokes i worked with even after 2 years had to sit in their cabs for a few minutes drawing diagrams to get their heads round the car layout on the lorry.
You must recall even back when the bodies were simpler what a multi drop could be like, the job is like no other.
I’m not trying to argue with you Albion, far from it, much of what you write i agree with but i’ve seen more than enough hopefuls who appeared to take to it well at first start well and once reality hit them leave again in short order, or worse get sacked due to excessive damage after a few weeks/months, there will be damage at first there usually is but companies realise this, if you learn from it and don’t make a habit of it that’s acceptable.
Yes some take to it like a duck to water even starting on the most complicated bodies, and good luck to them cos they have a well paid future, but these are the exception IMHO and not the typical.
