I’ve been making a few enquiries over the last few weeks on the practicalities on running on gas.
It would seem that two types are available that would be suitable to LGV’s. CNG (Compressed Natural Gas) and LNG (liquefied natural gas).
I discounted CNG as supply in the north of England doesn’t exist so I’ve followed the LNG route. I managed to pick the brains of an engineer who has converted trucks to run on gas. (i can’t seem to find that much relevant info off the web)
Anyhow it would seem that although it’s possible to run a truck on 100% gas it has 2 big disadvantages. The engine has basically to be redesigned to run as a petrol engine, spark plugs, ignition system etc. Then when it runs it has the characteristics of a petrol, no torque. However, if you run it with a mix of gas and diesel the engine needs little modification and the response from the engine is identical although a little quieter. It’s typical to run on a mix of 40% diesel and 60% gas. The MPG figures for the vehicle will remain the same.
The cost of conversion is around £2000 (bit more if the air tanks need moving etc.) although on top of this is the price of the tank. As LNG is stored at -160 degrees these are a fortune, between £5000 and £8000 depending on there size.
So anyhow I sharpened my pencil and started doing a few calculations. I based it on a vehicle returning 8 mph and covering 1500 miles a week. (roughly what I do although I‘m only getting 7mpg out of my present truck)
Diesel £0.80 litre or 3.64 gallon
LNG £0.28 litre or £1.27 gallon
1500 miles @ 8mpg = 187.5 gallons.
Running on the 60/40 mix the truck would use 112.5 gallons gas (£142.88) and 75 gallons of diesel (£273)
Weekly fuel cost running on mix - £415.18
Weekly fuel cost running on diesel - £682.50
The annual saving would be £20’000 so the payback period would be 6 months.
The network of LNG suppliers include Whitwood, Lymm, lesmago, J24, J9 to name a few so no big hardship there… So where’s the big catch?
 ) transit buses spend all day in town so a cleaner fuel improves the air quality in the urban environment. Second, the push for CNG was implemented with a new vehicle so a new engine and a proper installation resolves the excess heat problem. Also, even if the engine was based on a diesel motor it wasn’t a conversion job but a properly developed and engineered evolution of the original.
