You can be certain they won’t pay your fine , and you will be blamed for the possible PG9.
I don’t take them out if they’re cracked never mind smashed.
another way i look at it is…im expected to fulfill my duties without fault....so why does
nt this apply across the board.whoever is in charge of maintenance procedures has failed,so must accept the consequences…not just brush the problem under the carpet and pass the problem onto somebody else(driver)
commonrail:
wouldn’t you just fix it?
it’ll save a lot of time and money.
i`d probably make it worse
I would as said above as the trailer lights cover it. I’d make 100% sure they knew it was damaged before I got there though.
Somebody has smashed this light cluster, and the operator knows about it
Then he has a duty to replace it or get someone else to take the trailer
mike68:
You can be certain they won’t pay your fine , and you will be blamed for the possible PG9.I don’t take them out if they’re cracked never mind smashed.
have you actually read the whole thread?
how can they give you a PG9 for something that is perfectly legal?
and how can they give you a fine?
or is it a case of you just want to be a lazy ■■■■■■ and use it as an excuse to go home and toss it off?
commonrail:
from your previous posts, i wouldn’t trust you with a screwdriver, let alone a truck
commonrail:
Unless the vehicle is either going, or likely, to bobtail somewhere on the public highway there is no urgency to replace and it would just be done on the next six weekly inspection.
Where do you end up stopping with defecting road legal vehicles. VOR’d for catwalk lamp not working and calling out a 24hr fitter’s van out. If it was me in the van being called out I’d be deeply unimpressed TBH.
and what about if you discover a chunk out of a tyre sidewall…dont think that
s illegal,but do you still take it out
commonrail:
just change it.
why bother…you aint breaking the law
commonrail:
it could blow out and do a lot of damage, so it’s worth changing.
anyway, it stops the boredom setting in.
scania730lover:
from your user name,i guess you`re more interested in fanny lights and ■■■■■ extensions than the overall condition of your truck
Yes I would, I’m Irish…!
limeyphil:
commonrail:
s illegal,but do you still take it outjust change it.
is the correct answer
commonrail:
are you quite sure about that?
it just goes to prove, some people are just too stupid for some things
commonrail:
scania730lover:
from your previous posts, i wouldn’t trust you with a screwdriver, let alone a truckfrom your user name,i guess you`re more interested in fanny lights and ■■■■■ extensions than the overall condition of your truck
what has my username got to do with anything?
you really are a tool of the highest order aren’t you
you come on here with your postings about what you would and would not do if a vehicle was defective (in your eyes), when most of the time, you are wrong
are you ROG in disguise?
