A Mercedes with a mobile home onboard,seen on the A483 in Llandrindod Wells, Radnorshire.
One of Phil Morris Daf CF eight wheelers,seen on the A44 on Radnor Forest near Cornhill, Radnorshire.
Are the tipper operators busy out your way, Dave? We’re flatout around here. I’m doing loads of work for customers I used to deliver to on Smiths. We’ve got a lot of new wagons coming too so things are looking good…
Dave ware that lives in eardisland.
escortg3:
A Mercedes with a mobile home onboard,seen on the A483 in Llandrindod Wells, Radnorshire.Dave ware that lives in eardisland.
Didn’t realise it was a local lorry Andrew.
A Volvo FM rigid with a load of straw, taking a break by the A44 on Radnor Forest.
hiya,
Looks a bit “baldy” Dave, to warrant being called a forest, but it
is a bonny part of the world.
thanks harry, long retired.
harry_gill:
A Volvo FM rigid with a load of straw, taking a break by the A44 on Radnor Forest.hiya,
About 1,600 feet above sea level in that layby Harry. Its known as Radnor Forest and was at one time covered in trees. There are still several thousand acres of forestry just over the skyline. Have a look on google earth you will see how big the area is.
An artic driver wouldn’t need to get up on the grass like this one, seen on the A44/B4357 junction at Walton, Radnorshire.
Muckaway:
Dont know about Dave’s area Nathan but Tarmac-Lafarge have recently closed the large quarry local to me, where Nigel (Armstrong) worked from. My old quarry (Ballidon, near Ashbourne) is virtually shut as well, apart from powders and blocks. The contract lads now run down to Mountsorrel (near Loughborough) and work from there or go across to Staffordshire and work from Caldon Low plant. So too answer your question, around here not much! ![]()
Pete.
windrush:
Muckaway:
Are the tipper operators busy out your way, Dave? We’re flatout around here. I’m doing loads of work for customers I used to deliver to on Smiths. We’ve got a lot of new wagons coming too so things are looking good…Dont know about Dave’s area Nathan but Tarmac-Lafarge have recently closed the large quarry local to me, where Nigel (Armstrong) worked from. My old quarry (Ballidon, near Ashbourne) is virtually shut as well, apart from powders and blocks. The contract lads now run down to Mountsorrel (near Loughborough) and work from there or go across to Staffordshire and work from Caldon Low plant. So too answer your question, around here not much!
Pete.
Sorry I missed your post last night Nathan. Quite the opposite to Pete’s area,the quarries this way are flat out with tipper operators struggling to find drivers for night work and weekends etc. Also a lot of artics on regular work full time from these quarries. There are a lot of artics from all over the UK picking up loads as well.
A lot of new wagons have been put on the road in the last six months as well.
Hi Dave nice picture , does much heavy stuff use the A483 now ? regards Keith
kingswinford kit:
A Mercedes with a mobile home onboard,seen on the A483 in Llandrindod Wells, Radnorshire.Hi Dave nice picture , does much heavy stuff use the A483 now ? regards Keith
I’m not in Llandrindod as much as I was a few years back Keith. I think a few wagons still go up the A483 through to Newtown and vice versa,but I would think the majority use the A470 especially after the improvements between Builth Wells and Newbridge on Wye.
