VOSA Inspection on Monday
Own Account Driver:
newmercman:
Chaversdad, I’ve had a Scania and a Magnum fail on the parking brake, both 4x2s with park brake on drive axle only and they still have to meet the 12% of design weight criteria, both had a reline within a month of test and new brake chambers immediately prior and both failed, I got around the Magnum by having a brake test only before the test and when I knew it wouldn’t pass, by using a trailer with concrete blocks set up for 6 wheelers so it had a load of weight on it and it just scraped through, but that poxy Scania was a nightmare. I ended up speaking to an engineer I know at Scania HQ and he put me straight on how to get the design weight lowered to 40tons so it would pass, which it did :sunglasses:
I phoned up Cambridge (I was Eastern Traffic Area) and told them all about it, bloke there told me I’d done the right thing as I was moved straight to the top of the must visit list after the MOT fail :cry:
We have this a lot, I have to put new pads in one of mine every year to get it through, very annoying when it obviously isn’t a maintenance issue.
The really annoying thing is that it isn’t a level playing field, the plated weight should be the value you need to beat, not the design weight :unamused:
