Best line from the show has to be “mark is on the dreaded multi drop today”. Leaving the Widnes depot and doing 4 drops around Manchester, I do that before breakfast.
Dalehead:
+1
I do 15 of the buggers in 5 - 6 hours
‘Best line from the show has to be “mark is on the dreaded multi drop today”. Leaving the Widnes depot and doing 4 drops around Manchester, I do that before breakfast.’
lol +2
1FLEETRENEGADE:
‘Best line from the show has to be “mark is on the dreaded multi drop today”. Leaving the Widnes depot and doing 4 drops around Manchester, I do that before breakfast.’lol +2
Aye it must be hard work at stobbies,zzzzzzzzzzzzzzzzzzzzzzzzzzz.
regards dave
Is Fiona now history on Stobbies’ Soap Opera? I assume so.
It begs the question, ‘will there be another female driver taking part that is sort of attractive?’
Truckulent:
Is Fiona now history on Stobbies’ Soap Opera? I assume so.It begs the question, ‘will there be another female driver taking part that is sort of attractive?’
She dropped a massive bollock that time she went out with a trailer that had a tail lift(she had never used one) and she didn’t take the Anderson lead either. She never went into the planners to say she had never used one just went out with it and got about 4 hours behind and had to wait for the Scouse fella who has teeth like a pan of burned chips to bring the lead out
SteveBarnsleytrucker:
“One slight wrong move of the steering wheel and Mark will be in the North Sea! There’s harldy enough room to swing a cat let alone a 44 tonne artic. Driveing right out of the top draw by Mark Dixon a round of applause from everyone watching and Mark is on his way! He now has 3 days to get to Teesport in Stockton,if he doesn’t get there in time the Tesco RDC will not be able to deliver it’s stock to Tesco shops around the country,people will starve! will he make it in time? find out when we return after the break!”
You dont own a vw and park it on the a180 do you , your tale is so accurate i think your a secret stobby spotter
OTS:
“One slight wrong move of the steering wheel and Mark will be in the North Sea! There’s harldy enough room to swing a cat let alone a 44 tonne artic. Driveing right out of the top draw by Mark Dixon a round of applause from everyone watching and Mark is on his way! He now has 3 days to get to Teesport in Stockton,if he doesn’t get there in time the Tesco RDC will not be able to deliver it’s stock to Tesco shops around the country,people will starve! will he make it in time? find out when we return after the break!”You dont own a vw and park it on the a180 do you , your tale is so accurate i think your a secret stobby spotter
S–t! You’ve caught me out!
your other half isn’t a women/man?
mickyblue:
A bit of both.
Truckulent:
I heard they have got Lisa and Maya from IRT
mickyblue:
I struggled a bit with that particular episode. I couldn’t figure out why the shim was getting it’s knickers in a twist because it couldn’t get a double ES duvet cover. Surely an extra pillow case would have sufficed for his/her companion?
the maoster:
Ha ha ha.
OTS:
Wonder if the fella on A180 has got this on his front room wall stobartclubandshop.co.uk/hom … order/0/1/
iceman1:
agh come on mr bladden, you got told theyd be ther and you jumped up and down to get that run so you could be in the stobart gang heeeeee heeeeee
nope , was in company car taking an order , then returned to deliver it in a DAF , why would I want to be on tv
Rikki-UK:
“One slight wrong move of the steering wheel and Mark will be in the North Sea! There’s harldy enough room to swing a cat let alone a 44 tonne artic. Driveing right out of the top draw by Mark Dixon a round of applause from everyone watching and Mark is on his way! He now has 3 days to get to Teesport in Stockton,if he doesn’t get there in time the Tesco RDC will not be able to deliver it’s stock to Tesco shops around the country,people will starve! will he make it in time? find out when we return after the break!”■■■■ it they moved Teesport and no-one told us
great , it wont take me half as long to deliver tomorrow then
