Wednesday night. I’m still trying to figure out if I actually did any work
Back at Roadways again at 1800 and,
"There’s the keys for X235LBJ [FM12 380]. You’re relieving the day man shunter up at Next at South Elmsall. Go up unit only and there’s 3 trailers up there being tipped. If any of them have been tipped then get the day man to bring one back and then sort the other two out. If they’re done in time, pull one off and park it up and then bring the other back with you.
After that you’ve got a 2359 booking at Ciba (Allied Colloids) at Low Moor, Bradford so leave yourself enough time to get back down here, swap over and get over there okay?".
No problem. Got up to Next at 1840 and after a few words with the day shunter he disappeared with a 20fter and I was left baby-sitting a 40 and another 20. The 20 had 3 different drops on it and was to be re-sealed when they’d taken what they wanted out of it. At 1850 it was ready to be pulled off. I asked what time the 40 had gone on the bay and it was only at 1815 and the estimated tip time was 8 hours
so realistically, that would be staying there for the night.
I pulled the 20 off and sealed it up and then got my head down for a good 3 hours kip
. The bell rang at 2215 and it was Paul from the office.
“How you doing up there?”.
“The 20’s done which I’ve pulled off. Just waiting for the 40 now”.
“Okay, I’ve got someone else to do the Ciba job as it’s quiet so get your head down for a bit”.
“Okey-dokey. What time should I pull out of here if the 40’s not done?”.
“Ring me or I’ll ring you at midnight”.
. Excellent, more sleep.
Got my head down again and set my alarm for midnight
Checked the 40 again and still a red light so I belled Paul.
“Okay, it’ll have to stay where it is then. Back down here Rob, there’s a 40 to load at Scottish Courage at 0300 for the train so whenever you’re ready mate”.
Trundled back down to the container base, dropped and swapped, picked my note and bolt seal up then off to Normanton.
Went in to see the Hayes lads and the load reference number was wrong. No amount of checking and re-checking would rectify it so I had to pull out empty and return to Leeds.
Nothing else to do so I was away at 0300 having done absolutely nothing for 9hrs but lined my pocket with £76.50 at the same time. More! More!
