How does piggy backing truck trailers and hauling containers,which previously went ‘regularly’ by road,fit the description of ‘regular’ ‘train sized’ loads.
If you have 50 containers regularly travelling from one end of the country to the other, that is a train sized load. The main obstacle to containerized loads in the past was the height of Victorian bridges, which are steadily being improved.
Or for that matter we obviously wouldn’t be dealing with any issue of any deliberate stated government policy of large scale ‘shift’ in freight volumes ‘from’ road ‘to’ rail.Which we obviously are.
I haven’t said any such policy does not exist, although I’m not familiar with it. It just seems to me a perfectly natural result of rail’s efficiencies, which is why every decent economy in the world has a rail freight system.
On that note if rail is as efficient as it says it is then it has nothing to fear by allowing trucks better access to those same markets in the form of a leveller playing field regarding fuel costs and efficient vehicle specifications ( LHV’s ).Nor would that issue of stated government transport policy exist.
I have no personal objection to LHVs - all I’ve pointed out to you is that they’ve looked at the current market and decided that amongst other things: a) it will require infrastructure improvements (such as for parking), b) it will require route constraints, c) certain designs of vehicles are more demanding on drivers (which will require more constraints on hours and scheduling). All this will require capital investment and therefore an increase in taxation.
As for the poaching of loads from rail through so-called “modal shift”, they have basically concluded that this will not just cause marginal losses to rail (which of course would be perfectly justified if trucks were more competitive for those loads), but will potentially undermine the economics of the rail system and investment plans which depend on high utilisation. That is the official position.
My position goes further to point out that the so-called competitiveness of trucking is primarily as a result of its inferior terms and conditions, and that once these are equalised, once trucking’s “unfair advantage” over rail is removed, it will not even come close to competing with rail.
I also simply don’t accept your point about red diesel being unfair - road fuel duty is the price operators pay for the infrastructure, which rail pays for in other ways (typically today in terms of track access charges I presume, whereas under British Rail it was simply all paid for and accounted for internally by the same firm).
I would happily have a more detailed discussion about the fairness of red diesel, if you have more detailed figures or sources to refer to, but as I’ve said I suspect the defect in your thinking is in assuming that the unfairness is self-evident (presumably based on a paranoid perception that even right-wing Tory politicians have some sort of grudge against trucking with its supposedly supreme efficiencies over rail).
While so long as it does exist why would anyone with any sense choose to enter the road transport industry given the choice of entering the rail transport industry instead.While road transport will obviously increasingly be seen as the second class,second choice with drivers treated and paid in line with that situation.
I’m happy for rail to be seen as the more attractive career, because in fact it is so. You’d need your head examining if you told some school-leaver to turn down a secure job in the rail industry to come and do the average truck driver’s job. Even our very best and most responsible jobs like fuel tankers or some of the specialist chemicals (which don’t even begin to represent the majority of trucking jobs), no longer have final salary pensions for new members, and you’d need a letter from the pope to get straight onto fuel without spending 10 years crawling through the industry’s sewer entrance.
As for road transport having “second class pay”, that is not because of poor productivity, it is because of a simple class war between workers and employers which the employers are winning. You’re being so obtuse about this that I can’t make sense of why you’d overlook the obvious answer about why pay and conditions are ■■■■■■ to try and make some ridiculous argument that the failure to adopt LHVs are the reason why driver’s pay has fallen over 20 years (let alone failed to grow).
Given a situation of equal unionisation between rail and road,in which wage levels are removed from the competitive process for both,that doesn’t fit the definition of ‘under cutting’.
I agree, but we’re not in that situation! Trucking is only as competitive as it is with rail, because it has such dramatically poorer pay and conditions, and even then rail still manages to outcompete trucking.
While imposition of unfair taxation and ‘unrealistic’ vehicle dimensions and weights,together with a stated government aim of removing road transport’s access to the transport market,certainly does fit the definition of ‘rigging’ the market.Those dimensions and weights being no less unrealistic now than the 32 t gross limit was before the pathetic move to 38 and 44t operation.While the difference in fuel costs regards the two modes speaks for itself.
There is no difference in fuel costs. There is a perfectly fair difference in fuel taxation, because that is how road haulage pays for infrastructure, whereas rail pays for infrastructure with track access charges and similar (the equivalent in trucking would be for the government to charge truckers for every road journey they booked).
As for the lost tax revenues from trucks’ use of red diesel yes they will need to be made up from an increase in central taxation like income tax.Rather than regressive VAT and Duty which hits the road transport industry and those employed in it disproportionately.Or for that matter the customers of everything moved by road.On that note I thought Labour was all about taxation based on the ability to pay.Not hitting poor pensioners’ etc grocery bills in the form of passed on road fuel duty.
Again, the answer to “poor pensioners” is better pensions in the first place, not constantly trying to battle for exceptional tax breaks to everything.
