Ok, I’ve been getting more and more intrigued by this one, as I’ve always been taught NOT to DDC a synchro because it damages it - the first time I remember quite clearly because I was working for that General and Ag firm and had been driving Twin Splits and Roadrangers for them continuously, until one day they let me loose in their single FH12, after a half hour lecture on not blipping the throttle etc etc etc.
Anyway, having been told the same so often since, and seeing such a split in opinions here, I went and did some brainpicking with the two mechanics I most trust in order to try and get a resolution and some concrete details…I tried to put some of the counter-arguements as well, to be totally fair about this. Here’s the results:
EXPERT ONE - 60yr old Fleet Manager with 40 years experience on all types of vehicles, both HGV and Non-HGV.
Does DDC-ing a Synchro box cause damage? - “It certainly wouldn’t do it any good.”
In what way? - “It would cause premature wear.”
How? - "By forcing the synchros to do more work. "
But surely by matching the revs you are taking work away from the synchros? - “No, you are just forcing them to do more work on the opposite “side”,”
EXPERT TWO - 50(ish)yr old Deputy to the above with about the same experience on the same types of vehicles. More inclined to take the time to explain stuff properly.
Does DDC-ing a Synchro box cause damage? - “I wouldn’t of thought so. How can it? It’s just pointless because the synchro cones do it for you.”
In what way? - “Well, all the synchros do is slow down the gears so that they go straight in.”
How? - “Well, you have like rings, or cones, which will slow the spinning cog down to match the engine. On the downchange, they slow the cogs on the engine side down instead, so blipping the throttle just does what the synchros would have done for you - it’s pointless. Especially considering that the synchros don’t do anything until you move the gearstick, so DDC in itself won’t do anything at all other than giving you a sore leg. It’s old Grandad driving.” (doesn’t beat about the bush doesn’t our Steve!)
So when you get an old, tired, synchro box that needs the odd blip here and there to get it to behave, that’s not a result of people DDC-ing it in the first place? “I don’t see how it can be” (repeats the above in more detail, but you get the jist) "If anything, it would wear out the clutch with all the pointless de-clutching. Not the plate, obviously, but the clutch pack. So from that point of view I wouldn’t do it - that and the fact that it’s pointless Grandad driving. "
So what does make a synchro box get tired like that? “The same thing as wears out all gearboxes - drivers leaning on the gearstick as they’re going along, usually.”
So…Between these two, the jury’s out - although I have to say I’m far more convinced by Expert 2 at the moment, if only because he was able to back up his arguement with factual explanation. To be fair to Expert 1, though, he was up to his armpits in bulk box liners and white powder at the time of “collaring”, so didn’t really have the time or oxygen to get into the whole thing on a deeper level…
This is really fascinating me now. I’m really glad it’s come up, because it is, I admit, far too easy to just be told the same thing over and over by different people and take that as gospel. I do still remember clearly De Saint’s explanation, complete with diagrams, but it has sadly disappeared into the PDA archives (they’ve upgraded since then) and the man himself seems to have gone offline. I’m on hols until next Wednesday, but will start collaring yet more random technicians on my return and see if I can dig up anything else…As I said, it’s fascinating me now, so a big thankyou to Dave and Zetor above for giving me the impetus to actually question the details of this! Jeannie the Jinx is bound to break down and land me in a dealership soon, so I’ll have a whale of a time working my way through them all…ahem…
The clutch-pack wear intrigued me. Perhaps that is actually the main reason why the practice is discouraged on heavier vehicles, and just telling drivers “stop it, you’ll [zb] the synchros” is easier in a busy yard than going into a full explanation…who knows…
I still think it should be taught after basic training though. Bearing in mind that they teach “brakes to slow, gears to go” these days, it makes more sense to just get trainees to slow down enough on their brakes for an easy downchange, rather than contradicting that policy by then making them double-declutch and do the work through the gears. Otherwise surely it will only serve to confuse the issue, which brings us back to overload.
The above suggestion does work on boxes with no synchro on 1st and 2nd, by the way. I tried it only last night on my 1967 Landrover, which I normally double-declutch, and even the knackered 2nd gear which jumps out as quickly as you take your hand off the lever stays in quite happily if you slow her down enough first. Bloody thing then stalls because the mixture’s a bit iffy, mind…but that’s another story…
…Point is, the gears go in, and there is no need to DDC it in a gearchange exercise situation even with out the lower synchros.
Ps. Apologies to anyone stuck behind the Landrover behaving oddly in Lazenby High Street last night. Never let it be said that I’m not prepared to look a complete ■■■ in order to check my facts.
