[zb]
anorak:
860 lbft NET TL12 by your own figures.
V 870 lbft Eagle which part of 870 NET INSTALLED didn’t you understand…
That Eagle is the 320bhp version; you comparing it to the 280bhp Leyland. 0.11% more torque, from an engine in the next power category up. It doesn’t matter how much you shout and stomp, that is one weak argument there.
Why are you saying the Eagle is superior to the TL12? Oh yes, it was lower head bolt loads. Have you managed to calculate them yet?
Tell ya what- I’ll help you through it, with a series of very simple questions. Multiple choice, just like in the 1970s!
The engineers want to increase the torque of the engine, by making the fire in it bigger. Does that make the head bolt load:
A Smaller
B The same
C Bigger
Two 6 cylinder engines develop the same torque on the brake dyno. One of them is a big engine, the other a small engine. Both have a 1:1 bore:stroke ratio. Which has the higher heat bolts loads?
A The big one
B The small one
C Both the same
Two 6 cylinder engines have the same capacity, and develop the same peak torque on the brake. The blue one has a stroke 5% longer than the red one. Which has the higher head bolt loads?
A. Both the same
B. The red one
C. The blue one.
So which TL12 could offer more than 280.That’s right it couldn’t.So you’re saying we musn’t fit anything better.Which is actually exactly what Leyland did.They lumbered it with the ‘280’ TL12 at launch instead of the Eagle ‘320’.
Having flogged off RR to the lowest bidder.Why would you want to do that instead of ditching the TL12 and bringing RR in house for no charge.That’s sabotage ordered at the top.Not militant workers.
How much torque was the Eagle ‘320’ making at 1,200 rpm as opposed to 1,300 rpm.The fact that it was making more than the TL12 at 1,300 doesn’t mean that it was making less than the TL12 at 1,200 rpm.
The 311 rating was made by taking ( a lot ) more torque, than the TL12 made at 2,000 rpm, up to 2,100 rpm.What’s that got to do with the peak torque figure.It has everything to do with the TL12’s laughable torque drop at peak power.
1 Define making ‘the fire bigger’ ?.
You mean the engineers want to increase torque by increasing cylinder pressure ?.That obviously proportionately increases the load on the head fastenings.They want to increase piston area that obviously doesn’t.
2 More piston area means less cylinder pressure so less head fastenings load for the equivalent torque output.So it’s the smaller engine.Who would have thought it.
3 The TL 12 had 7% less stroke not 5%.It had a 4.6 % piston area advantage.So zb your trick question.
Oh wait in addition to the TL12’s piston area v leverage deficit what happened to the end bearing loads in all cases regards increasing torque by anything other than leverage.
So AEC made a lemon by the standards of 1979 and its production tooling was worn out anyway. You’re saying that we musn’t fit anything better in the form of the 320 Eagle in the Roadtrain.Why would you want do that.
