[zb]
anorak:Carryfast:
… you can’t get 246 psi BMEP from a TL12.Is that because there is no such thing? What if you polish the rocker cover? Will a genie come out of the exhaust manifold?
It is too stupid to know exactly HOW that torque was produced by the engine whether by cylinder pressure or piston area or leverage.That is exactly what you are doing, by declaring that one engine, of similar capacity to another, but with a shorter stroke, will blow its head off, if both engines have the torque output increased. By saying that the TL12 will batter its bearings and destroy its head gasket, if it had been developed to produce a similar torque to the later Eagle engines, you are using the variable (BMEP/stroke). If you had other information, such as cyl pressure vs. crank angle for both engines, your declaration might have carried some weight, but you can only cite the parameter of which you deny the existence. That is the centre point of the stupidity.
It’s only the TL12 that needs its BMEP/Specific torque increased.
The Eagle is already there at 1,216 ft that’s close enough to 100 lbft per litre to provide 246 psi BMEP.
Oh wait you’re in denial that that amount of specific torque output = 246 psi BMEP because you don’t accept the formula specific torque x 2.464.
So you need 43% more specific torque with a 7% leverage deficit.
Also a 2.5% piston area deficit v the Eagle’s leverage advantage.
Tell us how you’re going to make that torque reuirement.
The required extra cylinder pressure is going to wreck your head fastenings.
The required extra force required on the con rod is going to wreck your end bearings.
There is no stroke or piston area variable in the BMEP calculation.It’s is just based on specific torque at the flywheel regardless of how its produced.Which makes BMEP an oxymoron in itself in creating the erroneous premise that more specific torque/BMEP by definition means more ‘cylinder pressure’.Which the two variables of piston area and leverage prove is bs.
Not to mention numerous documented statements confirming BMEP doesn’t mean cylinder pressure as I posted.It’s a non existent abstract hypothetical comparator that’s all.Might as well use the specific torque figure that it’s based on.BMEP couldn’t possibly be a measure of cylinder pressures no matter how much those with your erroneous ideas try to say it is.
It’s a measure of specific torque.Which is made up of the combination of cylinder pressure, piston area and leverage.Leverage having the advantage of multiplying the effort of both of the former and you’ve got a 7% deficit of it.I’m still waiting for your answer to the question can you make an F1 engine produce its around same 200 psi BMEP but at 1,200 rpm.If not why not.
You have nothing to back up the assertion that the engine will wreck its head bolts or bearings, other than torque, capacity and stroke. If the parameters you are citing cause force on the parts you mention, you need to arrange them in the expression F∝T/V.s, or F=P.A. Simplifying every piece of bolleaux you say comes back to that. You have nothing else but those parameters, so you are citing BMEP, in ignorance, while denying it has any actual physical use LOL. If you were not completely oblivious to very basic algebra, you would realise how foolish your waffle is.
Colour- I like it. Good idea, Mr. 551.
