[zb]
anorak:Carryfast:
Tell us did your bs ‘derivation’ match specific peak torque measured at the fly wheel x 2.464 yes or no.I actually saw no engines ( like TL12 or Eagle ) being referred to in that bs…It’s all up there^^^. Not yes, no. 4.π is the constant. Don’t know where you get the 4.22644 from. Don’t tell me you worked it out yourself (I would actually have some respect for you , if you had). Why would I have to mention an actual engine? The equation applies to all engines.
PS are you now agreeing that BMEP is pressure, or is that understanding still the preserve of the older kids?
Which part of BMEP is purely theoretical it has nothing to do with actual cylinder pressures.By looking at the equations you can easily see that BMEP is simply torque per cubic inch of dispalcement ( specific torque ) didn’t you understand.
There are other constants which can be used I’ve posted them within the above statements.None of them include bleedin Pi.
So tell us why can’t an F1 engine produce its peak torque thereby its peak BMEP from 1,200 rpm given sufficient boost.You’re obviously saying that the required cylinder pressures would be the same.
As I said BMEP doesn’t even actually exist in the real world so I’m obviously not agreeing with your total bs bordering on trolling.
