[zb]
anorak:cav551:
Peak Cylinder Pressure and compression pressure comparison is not the easiest thing to understand. Taking a ratio of 16 :1 we would assume that in a naturally aspirated engine that the pressure at the point the inlet valve closes is at atmospheric pressure 14.7 psi so 14.7 x16 = 235.2 psi. However that is not what one will record with a diesel compression tester. Carrying out such a test one is looking to achieve figures around 400 - 450 psi. However temperature and rpm come into play. A compression test is usually carried out either to daignose which cylinder(s) are causing an issue or why an engine is hard to start. Testing with the engine running at speed and full operating temperature is not often done for safety reasons. The closest one can get is an engine which has been run but is being motored by the starter motor. This is what one is advised to do but does not pin down a cold start problem since the readings will be higher. Stone cold at an ambient single figure Centigrade one can expect to have to accept 350+ psi as the barest minimum for a worn but not worn out engine.However as the first image shows (at an albeit higher ambient) the theoretical pressure is significantly greater. The second image of a speed/ pressure/ crank angle with a fixed injection spill point shows a much higher peak cylinder pressure and identifies how combustion develops…
Compression pressure isn’t the same thing as compression pressure + and including the pressure created by combustion.Which is the peak cylinder pressure on the power stroke at peak torque under load and you don’t have a tester strong enough to measure that.That will be measured in 10’s of Mpa not psi.Especially when forced induction is added to the compression side of the equation.
At what pressure- or abstract quantity which is not pressure, but is measured in the units of pressure, for no reason that we can begin to explain- do we convert from psi to MPa?
Is that the same non-pressure that we do not possess a pressure gauge strong enough to measure, or some other abstract value? Given that, further up the page, we read a link which showed peak combustion pressures of no more than 3xBMEP, these cut-off points must be clustered within a close range of pressures. I’ll guess at somewhere between 200psi and err… 1.0MPa.
That same link referred to a peak combustion pressure of 75 bar, which is 7.5 MPa. Which engines have peak pressures in the 10’s of MPa? I’ll have a guess- the BMC C Series?
That’s what is then transferred to the head fastenings.Chorus All together now,
43% specific torque deficit with a 7% leverage deficit is a lot of extra pressure factoring in your 2% piston area v leverage deficit.
Your end bearings are going to get hammered by taking the full 43% torque deficit x 7% leverage deficit regardless./quote]10-1 Mpa instead of just saying Bar it took a magnifying glass to find the -1.
‘Further up the page’ was an NA engine comparison.
Call the turbo 320 DS 80 bar so more than 1,000 psi.
Oh wait the thing is still only putting out around 55 lbft per litre and that with a bore stroke ratio of 0.90.
How are you going to almost double that specific torque output.
How much is 1,000 psi on the area of a piston when transferred to the area of an end bearing shell and head fastenings cross sectional area.
Oh wait you don’t even believe that leverage plays any part in the torque figure.Nor can be substituted for cylinder pressure and force on the con rod.
