Tachograph Removal
Totally bewildered just found this post.
I have a Man Tgl 7.15 which I purchased 2 years ago for private use for chassis swop for old daf 45.
Never turned on tachometer because only private use.
Yesterday getting tacho malfunction and on board computer malfunction signs on screen as well as permanent engine management light and hazard light on screen.
Been quoted £1500 for new tacho plus calibration.
Is anyway it can just be disconnected Been told has to be on vehicle but I notice you can fill out exception form for testing.
I
Big Truck:
There is a factory near Budapest dedicated to manufacturing “black boxes” to disable digi-tacho without messing up truck electrics.
Was told EVERY truck running in Hungary/Romania has one fitted!!!
Should be able to find them on Google.
Sent from my SM-J500FN using Tapatalk
There is also one in Great Britain…
Hi I’m in Tauranga NZ and I have the same problem with my 2011 Mercedes Axor. It went to MB for a gearbox repair and now every time the truck starts moving (like 20-30 times a day) it comes up with a VDO TACHOMETER error on the driver dash. When the error is there you lose the truck digital speedo display and only have the analogue speed meter, Looks tacky and annoying. I’ll try to post a photo. I’ve lived with it but am now selling the truck so keen to get it sorted for the new owner. NeonGreen if you get this message and have a solution could you email me Medworx@xtra.co.nz Cheers, Terry
I’ve tried to get MB to sort but they have not seen this before (because it is a Euro Import) and each time I’ve gone to take it back either the technician or Scan Tool hasn’t been available, so I’m keen to either fix it myself or give them some insight on a solution. Cheers
Horsebox owners in the UK experience similar issues. The internal battery will cause all sorts of problems if it goes flat: the automated gearbox will throw a wobbler without a speed signal and the vehicle cannot pass roadworthiness inspection without a functioning speed display, it will also often trigger an engine mil light or emissions warning. In normal circumstances the battery is changed at recalibration time. Take the truck back to the MB dealer who did the gearbox repair and ask them to contact Germany for recalibration instructions. If the battery is left completely discharged for several months then the tacho can be scrap.
Hi neongreen
I’m also in NZ and having problems with a UK import where the tachograph has failed and therefore the speedo is not working. I’m struggling to find suppliers here. I bought and was sent a tachograpgh from the UK to be installed but it changes my Km’s to over 500,00. Please help :slight_smile:
Hi Sammyscuba
I’m looking for a Nz supplier, I also have a LF45 where the tachograpgh has failed, no speedo. Please help I’m stuck. I sourced a new tacho from the UK but it wants to add 500,000 km to my odo. Thanks so much.
Hi
I sourced a new tacho from a New Zealand company, fitted it and it worked out fine. It was a while ago so give me a bit of time and I’ll try and find the company that I got it from - I remember they were in Auckland. I might have to ask my hubby who is away at the minute. Anyway, I’ll come back to you when I can. Cheers, Sam
(Ps - who made your truck and what year is it ?)
Actually, I found it !
You need to contact this fellow. Really helpful. He makes up a simulator head for the vehicle. Works a treat!
Bob Edmiston
Robinson Instruments Ltd
13 Fleming Street
PO Box 13426
Onehunga
Auckland
New Zealand
+64 9 6365836
Brilliant thank you so much!!!
My Truck is a 2011 DAF, I imported it via Grace at UK truck imports.
Cheers
Lena
