Quinny:
Two steep ones spring to mind…1st,is the A174 at Saltburn near Redcar,where there is a double hairpin,which,on the downward trek,means your nearly on the beach.I can’t remember how steep it is,but I’m sure either Rikki or Lucy may be able to enlighten us.Coming up,you have to use all of the hairpins to get the angle of the dangle right,otherwise you have to,if forced,stop and set off again.No mean feat if you’re quite heavy.
The other one,is on the B6278 Stanhope to Barnard Castle road.From the A689,you cross through the ford,in Stanhope village,if your brave enough,and head on up the pass,as they say.You can see the hairpin at the top of the hill as you enter the ford,and,bearing in mind your wheels will be wet or damp,you tend to get wheelspin if you don’t go up in the correct gear.The other way to maybe avoid wheelspin,is to take the chicken route over the ford,about 100 yards up stream.Again,I’m unsure what the steepness is,but I’m sure someone will know.
However,I’m sure the steepest climb in the UK,is the very small road on Bealach Na Ba in Scotland.(Link below.) I seem to remember reading about this as a kid in my old mans AA book of the road.
Ken.
Used to do that 1 quite a lot with a container on, we used to load at Corus round the corner from there, great place as you had to drop your trailer on the door then go park up near the train track / cliff to enjoy the view for 3 - 4 hrs whilst they loaded it. 20’ IIRC??
But then you had to head back, think the box went to F/Liner Leeds or Manchester, but it could’ve gone straight to Seaforth, can’t remember. But I remember the loading and that road VERY well ![]()
One of the best jobs I’ve ever had and would do it everyday if I could.
