Day 4 over and after two mock tests, I am realising just how bad my general driving is. The one fault I was accumulating on was blindspots and mirrors. Averaged 20 driver faults
Not looking good for tomorrow unless I can pull it off by skin of my teeth
I now have fingers and toes and all other extremities crossed that I can give a good drive tomorrow
Don’t worry about it mate, just try and stay calm. It’s much easier when you’re on the test to clear your head and focus on what you should be doing as you’re not chinwagging with the instructor. Fingers crossed for you, good luck!
Sounds like it’s going well for you so far. Blindspots and mirrors are not my strong point either, although I’ve got the hang of the 4 over 4 gearbox now, I just got to remember to use the mirrors more before a manoeuvre and check mirrors and blindspots before pulling away everytime.
I’m starting at midday tomorrow so I’ll manage to get a lie in hopefully!
Hi dar1976, keep a level head on your shoulders - stay calm & you’ll be fine. Have you run through the show me tell me Questions (there easy) Good Luck for your test
Well I got through it with everyone still in one piece and the lorry was undamaged. The reverse I took a shunt on but then got it spot on. The controlled stop was ok although I skidded a little. Out onto the roads and a good drive
Back to the centre an hour later and…
6 faults !!!
Unfortunately 3 of them were serious. 1 was for a roll back of about 6 inches (if that) and then an accumulation serious for inefficient use of mirrors. Finally I pulled up opposite a driveway for downhill start. Just a few issues with finding right gear which gave me a couple of minors. So all in all a fairly good drive with a couple of silly errors. They have booked me in for 4 hours on 22nd October and then a retest on 26th. So not long till I get fireworks too !!
Unlucky Dean but you don’t seem too downbeat about it which is good. Just got to dust yourself off and try again. Good luck for next time and be sure to let us know how it goes!
Bad luck but as has been said you dont seem to down about it but you now know what to expect & like you said a few silly things which can easy be sorted just remember you only have to prove to the examiner that you can drive control & be aware of your surroundings with the size of the vehicle
Good luck for 26 th hope it goes well & sensible having a ew more hrs before test
i know how you feel as i have just started training but it sounds to me like you can actually drive and its just simple things that have failed you , this is a good thing as simple things are easy to rectify, just focus on them and keep your other driving on a level and before you know it you will pass
That’s a bugger mate. No bother, at least you know where you’ve gone wrong and it’s a fair cop. I failed my first one for overtaking and for planning/awareness. Apparently I undertook someone which I never even realised I did. Asked the examiner to explain where I’d commited these offences but his answers were a little ‘vague’ … Second one I shagged up fair and square but that’s for another day
So sorry to read that you didnt get your pass, why the gap between 4 hours on the 22 oct & the retest on 26 - will you have a few hours driving on the day of your next test, or have they booked a very early morning test -( just , maybe a different time of day may suit you better). Fingers & toes still crossed for your next test, Good luck Dean
I get an hour before the test as well so no bother really. Still not getting in a tizz over it. I failed fair and square and I will get through it on 26th
