barreiros:
…Where do you take any connection between Paul and Roset from?
Paul was a cabbuilder that worked for a while together with Van Weelde, who built bodies. It made sense to combine the two enterprises to a one-stop-shop, where you could get your cab and body built. However, after a while, Paul parted again and opened a shop in Rotterdam. I’m not clear on the dates and reasons, but that’s the gist of it. Paul and Paul & v. Weelde cabs are basically the same product, unless they’ve been designed after the separation, then they’re just Paul, like the one from Veluwe Expresse shown earlier.
Here’s another Paul & v. D.:
Roset is the one that’s the most “cloudy” for me, if it is indeed Roset. I’d like to see any reliable info before speculating. But I have no information whatsoever on any Paul and Roset connection.
There are loads of photographs of Roset cabs all over the internet. There are also loads of photographs of similar cabs, with the coachbuilding attributed to P&vW. From memory, the first Roset cabs I have seen (on LV75 chassis) date from 1959. Elsewhere on this forum, possibly on this thread, I posted a picture of a preserved coach, from that period, which shared some obvious similarities. Based on that, this is a Roset cab:
The cabs attributed to P&vW (by the people posting the pictures) have some detail differences, principally the position of the headlamps, but are identical otherwise.
Based on what you have posted, it seems that Paul and P&vW, for a time, supplied cabs like this:
At some stage, they received panels or welded structures from Roset, and supplied cabs to that design. The vehicle in my avatar might post date that period, given that it has a late (TB) registration. The square-type Paul cab came later, judging by the UB and, in some cases, ZB plates on those vehicles. I must check all of these lorries’ registrations, so we may make some estimate of the chronology of it all.
I will finish by repeating a question I have asked before: given that those Paul cabs went on vehicles registered after October 1964 and, in some cases, had LB76 grilles on them, were those vehicles actually LV76s?
Incientally, I am certain you have seen the yellow P&vW-cabbed LVS on Flickr, with the R112 in the background. Was the LVS saved for preserrvation?
