One of four single wheeled TASK tandems stood in the depot at Milnthorpe loaded with 20 ton of paper for the South, I had these trailers built as tri axle chassis without the fron’t axle but ready to have a third axle fitted which we eventually had fitted. These particular trailer spent most of their time running out of the Devon Valley mill at Hele, light loads of paper outward and 20ton of pulp back to the Mill. Bewick.
Hi, in my 28 yrs of Ropes & Sheets,This is why i dont understand,why did certain people? always put the front sheet on first,& the back sheet on last,um? Norman croad,Torquay.
6LX:
If I was using someone else’s sheets I would occasionly put the front sheet on first then roll it back on itself to allow me to place the rear sheet on & position knowing all was well.
BACK SHEET ON FIRST,FRONT SHEET ON LAST,Norman croad,Torquay…
6LX:
Hiya,
Norman, now once or twice in my time on the road I recall loading multi-packs
a rare forklift job in my case, and because of the wet conditions have had to
sheet up as the load progressed, which mean’t put the fore sheet on first and
the aft sheet on last of course folding the fore sheet forward before putting
the rear on a bit of a fiddle but when needs must and the load must have to be
kept dry the driver can get ■■■■■■ through but not the load, should have had
those new fangled curtainsiders back in the 50s I might not have been quite so
knackered as I am now, Ah’ well.
thanks harry, long retired.
One of a number of Sed/Atks we had on our Paper Mill contract at Milnthorpe stood in the depot at Milnthorpe the pallets will be for a collection of some bagged chemicals for return to the Mill.Cheers bewick.
Hi Dennis,Yes ive sumtimes put the front sheet on first & rolled it forward do to rainny weather,& back sheet on last,& fiddled about, then yr putting yr fly sheet on wet sheets,hard work,in dry weather i put the back sheet on first & the front sheet on last,Norman croad,Torquay.
Hi, Folks , The S/A YEC 314 S ended up with us was a good tool did us proud , The old 180 d/b 6 speed box eaton 2 speed ,had to go in the end because of old tin worm , Cheers Barry
barrywaddy:
Came from a good home Baz !! but I bet it got a rude awakening when it arrived in your yard
PS Did you buy it from Ratcliffes ? Cheers Mr. Bewick.
HI, MR, Bewick, Yes she sure did , Cheers Barry
barrywaddy:
Did you get any of our other Sed/Atks Baz there was some R reg ones a little bit older than the S reg one you got. Cheers Mr. Bewick.
Mr , Bewick ,We bought about 10 S/A s ,from Bill Ratcliff but only one of yours ,Cheers Barry
barrywaddy:
Did you always go for the Gardner engine S/A’s Bazz ? Cheers Mr. Bewick.
Hi Barry
Here you go, a great line up of some of your Sed Atki’s found them on flicker
hope your well.
Hi, Steel boy f10, All but two of the S.A sleeper cabs were built by our Fitter ,two were works cabs ,you can tell by the two side windows ours were small the works were one big and one small ,just a bit of useless info ,Cheers Barry
Hi Barry ,is that your yard on the coast road with the 8 wheelers in one corner ?
Punchy Dan:
And what make is that old lorry by diesel tank in bottom left pic please Barry?
MAU 245W was ex Stirlands
