This looks to be identical to the control panel on the fridges I have been using, I don’t see the individual C1 and C2 switches?
Check out YouTube lots of advice on there .
the switches on our fridges which look the same as your picture are above the lid.
xamtex:
Thanks - Is that the flip up lid on the display panel?
fingermissing:
Thanks - I have, and I did find several video’s on them but none covering how to set up the compartments or alter the individual temperatures.
Try this one from a old trucknet user.
You may want to skip the first 5 minutes he goes on a bit.
MickyB666:
xamtex:
yes,switches are like the ones on the right of the lid
Thanks - I must of lifted the flap up and hid those switches behind the flap without noticing them - I will check it out ![]()
Up and down arrows to select the set temp required.
= button will set it. (Obviously when you have toggled between C1 and C2). You are doing it correctly when not requiring frozen, on let’s say a return journey. Simply leave the bulkhead dividers up and match C1 temp to match C2.
Found the compartment on\off switches - I was looking at trailers with only a single compartment set up and scratching my head as to where those switches where!
Single compartment trailer.
Two compartment trailer (note the toggle switches at the top of the display).
