rigsby:
I may have delivered that Buxton Limestone Scammel , we used to take the train to Windsor on a Sunday and bring new Scammels/Rievers back , cash in hand . Started off with old Rievers and mk1 Atkis until the new motors arrived . The quarry is now a caravan park and country park .
Thanks for your comments Dave.
Chris Webb:
“rigsby” “stargazer148” Hi Dean i was told mrs stood for morning roll service
I don’t know if it’s true though cheers Ray ps they were from Bathgate
Definitely right with the name , although they hated their cb name , Muppet Road Show back in the 80s/90s . I believe they started out with vans delivering morning rolls to the shops .
MRS,aka Muppet Road Services/Show had a depot in Chesterfield,I know somebody who drove for them,didn’t stay long though,you got yer hours in apparantly.
Cheers Chris.
windrush:
DeanB wrote: Intresting comments Pete.
I imagine the newer ones must be ok now. Out of intrest is there a time limit that the bodies have to keep the tarmac hot in the industry ?
Never done Tarmac work but i would imagine most
loads would go within a 50 mile radius of the depot
Depended on the material Dean, and if it was to spend days tipped in a council depot or being machine or hand laid on site. Wimpeys used to run reguarly into Kent with tarmac from Stoney Middleton and I have been to North London, South West Wales, Oxford, Newbury and near Kings Lynn and Ipswich. A full load should retain its heat for several hours if undisturbed, however one lad took two tonnes on a six wheeler to South London and it was like an OXO cube when he arrived on site!
Tarmac later visited the quarries and plants with infrared cameras, as the trucks were loaded they had to park up for thirty minutes and then the camera scanned the body to show up any heat loss. Usually the taildoor was the weakest part but some of the newer lightweight bodies were red all along the sides as well, they were not allowed to carry the hotter asphalts then. Mine was fine being a 13 year old body specced by ARC originally.
Diff locks: with Fodens own worm and wheel diffs like the S83 would be fitted with they were an option and Tilcon only ever ordered a ‘basic’ eight wheeler chassis (usually 100+ at a time) so ‘luxuries’ just were not specified. A private buyer would spec his own truck though. When the Paccar models appeared with either Eaton or Rockwell diffs a diff lock was standard, however cross locks were still an option so we didn’t get them for many years!
I occasionally spoke to a line manager at Fodens at rallies after he retired and he said that they liked the Tilcon orders as if a private buyer ordered a basic tipper chassis cab they would ‘borrow’ one from the Tilcon order and the customer was very pleased that he hadn’t had to wait long for his truck!
Pete.
Thanks for the comments Pete.
I suppose companies like Wimpey had contracts with Tilcon,so that had something
to do with trucks travelling further than seems sensible,when there must have been places closer they could have got the
same loads. Oxo cube !
With Tilcon’s buying power you would have thought they would have diff locks fitted as they would have got a good deal.
tyneside:
Thanks for your comments “tyneside”
When you bought that R reg Bison had those automatic tailboards just come out ?
Just curious as like i said yesterday i never realised they had been around that long.
Hi Dean
Just been thinking about this and the first auto t/g we had was actually on a new P reg Octopus (LPT 800P i think) with an aluminium body (the Bison that came a few months later was a steel body)
Both bodies were built by Northern Assemblies at Consett. It was their suggestion that prompted us to try one, but I am not sure where the original idea came from. IIRC the Octopus body was also the first one they had fitted with the auto system.
It was pretty simple really, a small air opertated handle next to the PTO switch which turned through 45 degrees to open the bottom flap and back again to close. The ram under the body pulled the bottom flap down (the flap was about 12inches deep). The upper part of the tail gate was conventionally hung on the top of the rear pillars.
In the early part of its life the Octo did a lot of coal and quarry work which was obvioulsy less harsh on the t/g and it lasted about 3/4 years but eventually it went on to muck shifting and more general work and again due to damage a conventional t/g was fitted.
Tyneside
Its amazing how time fly’s “Tyneside” i would have never thought they had been around that long.
Heres an early easy sheet system from 1976.
coomsey:
All the 8whlr ERFs I drove had difflocks fitted n on the odd occasion I needed it saved the day. However I used to backload Fullers earth from Leighton buzzard way n empty down the hole wether you got stranded or not was in the lap of the gods, never knew what to dodge to be safe. No difflocks or with difflocks high/low gear or high/low revs or any combination of it made no difference, the rrs end would bounce. Short wait n the shovel driver would turn up, with that look on his face that said " God help me! who’ve we got driving this thing?" The git never hopped in to show me how to do it mind cheers. The Fodens we ran never had the same problem so presume it was something to do with the ERFs suspension design. Cheers Coomsey
Good old shovel drivers !
When i was a kid we used to load out of Swanworth quarries in Worth Matravers. Exiting the quarry was a steep climb
and if it had rained you could not get traction.They had Volvo loading shovels and used to pop a chain on and pull loaded
artics up there like they were nothing.
