10/10 for effort. Driver gave it a bloody good go .I wonder if he managed to drive it out after letting the tyres down ?
The number & grade of bolts depends upon the “D” factor or Drawbar Value which will be stamped into the the manufacturer’s plate attached to the 5th wheel or the slider. This will be a Minimum of 8 M16x1.5 grade 8.8 bolts with a recommendation to use 12 10.9 grade bolts.
Formula D= 9.81x {(0.6xTxR) / (T+R-U)}
R = max GVW trailer T = Max GVW tractor unit U = Max imposed load on kingpin
Rochester
316412187_3365811243664006_6615318629573418944_n|690x428
Today Google Maps
Australia for the second?
Yes Frog, Brisbane.
He’s already in under, he may as well have kept going ![]()
Having done removals full-time for some years, I’m unconsciously switched on to height restrictions.
