Old trailer
jackslad:
waynedl:
hitch:
Can you do 44t on steel?
No, they’re only twin axle too. Can’t remember the limit on them, think we were limited to 20t max gross boxes? But it’s a long time since I’ve used one so stand to be corrected
I think vehicle excise duty is more expensive if you pull a tandem rather than a tri ,I wonder how many people check the disc.
It’s only a higher tax band if you go to 40t on 5 axles, 38t on 5 is the same.
DJC:
Do you mean a bit like this? :smiley:
I pulled the ratchet since it can only apply it further and that happened.
:grimacing:
I remember it was best to crank the handbrake on after removing the red line.
Do it the other way round and the cable would always slacken off a bit.
