MikeDBristol:
I agree with Evil8Beezle about 18 ton class 2 pallet work, it’ll be a good place to start for a variety of reasons.
Lorrys can only go so fast, so a days work can generally be around 15-25 drops and collections. You’re given a lorry with a route planned out, put the address in a sat nav and off you go, most places have a fork lift, open the curtain or use the tail lift to deliver. Onto the next drop until either you’re empty or the business’s have closed at 5/6pm.
As a new starter, most places will understand if you’re slow to begin with getting to know the addresses of customers and routes etc.
That’s about the size of it, and in my class 2 gig I drove a 26t MAN with a tag axle, rear steer and bags of tail-swing!
It’s nothing like what most people pass in, as why would the schools make the test harder than it’s legally required to be?
So REAL class 2 work is different from the test, and a Newbie should view mastering a BIG rigid with the same respect they would an artic, as real life in a bigger truck and getting the job done is way more challenging than the test. I’m a firm believer in “Earning your stripes” and think all Newbies should start on class 2, whether they did class 1 straight after class 2 or not. I’d be an embarrassed artic driver if I didn’t know EXACTLY how to handle a big rigid, and know what to watch for…
To give you an example, a big rigid driver will be watching his left hand mirror intently when turning right (especially if it’s a right hand turn lane) as they know when they make the right turn (which may be tight) and the tighter it is, the more the n/s arse swings left and you create a pinch point to your left, and if another truck was heading up your left things wouldn’t be pretty. Your general artic doesn’t drive like that, and the public do give artic’s more respect and space than versized VANS
So I’d put real life class 2 work down as an asset over someone’s CV, over someone who went straight to class 1…
Anyone thinking about pallets as a class 2 start, I suggest you check whether the VANS rear door is the tail lift or not (so huge), or some crappy little thing designed for cages and pig to use when trying to maneuver a heavy pallet, that you REALLY don’t want to land on you!
As for physical exertion; my experience was about 40% forklift drops in a rigid, and only a fraction in an artic, as not all the trailers had a tail-lift!
The route and drop radius also differs as local firms know the drops to send an artic to, and a non regular drop gets put on a rigid generally, but not always if the planner/router is sick!
F-reds:
albion:
2. I’m worried about you showing them up
Why oh why oh why doesn’t TNUK have a smiley that says, “I’m doubled up, crying with laughter so hard, I nearly [zb] myself. Twice.”
What you saying mate, can I put you down as a reference or what?
To be fair, I suspect Albion is more worried about whether her other drivers could cope with being cooped up with this bellend!
