Mazzer2:
WhiteDog:
I’d have to disagree with few of the above posts…I drive a 68 plate R450, 6x2. Company policy we must drop midlift axle when coupling with a trailer. After I hooked up and was pulling away, I did as I always do, and press the button to lift the mid lift. Sometimes is says something like “Tag axle overload” and it won’t lift. This time the axle lifted.
However this particular time I had access to a weight bridge, so I thought I’ll weight the thing… steering axle is permitted at 8000kg, but was sitting around 8300kg, drive axle was permitted at 10000kg, was sitting about 10222kg. I put the axle down and went through again… all well with in the legal permitted weights.
Reasoning always lift the midlift, guy from Scania was out with me, told me always lift it if it will, reduces drag and makes for better fuel efficiency.
But if the lift axle had been configured to your vehicles axle weights then it would have dropped 10,000kg limit on a drive axle is not the normal setting usually it is 11500kg so for whatever reason your company have specced the vehicle to that weight and then not set up the lift axle to match. The irony being is that the company probably watch the fuel figures and are quick to blame the driver for not getting good results yet company policy increases drag, wear and fuel consumption.
Our 4x2 drive axle is 11500kg.
Don’t know much about the inner workings of it all. Just stating my case from few weeks back, I was grossly over weight on axles, and never knew it as I was reliant on the truck to work out it’s weights.
