dieseldave:
A question for Judge Carryfast QC…
Could it be that there are two cases?
Is it possible that there’s case to be brought against the person responsible for knowingly driving a defective vehicle, but what about a case of driving without due care or careless driving against the person who ran into the back of it?
Wouldn’t both be triable to the extent of their contribution to the overall picture since both may have committed an offence?
I don’t know, but do you know?
Firstly we do know that the M62 mini bus incident resulted in two different cases. We also know that the truck driver who ran into the obstruction was cleared.
So, have we now established that it’s not a single case against the worst offender and the rest getting swept under the carpet?
Could it be that this idea is also happening in the case under discussion?
We also know that the Fed Ex driver has actually pleaded guilty to death by careless driving in this case.Which seems fair bearing in mind both your own view there,let alone the M62 example of not guilty of any offence ?.
I didn’t express a view… the clue is that everything I wrote had a question mark after it, so they were questions.
Sometimes, it’s a good idea to ask a question whilst already knowing the answer, which tactic tends to flush out the wafflers, googlers and bull manure merchants. All said whilst innocently looking up at the ceiling and having no particular poster in mind.
The question then is why did the prosecution refuse to accept that plea and why does the Fed Ex driver’s defence only see evidence of careless driving but not dangerous.
Why would that be a question needing to be resolved?
Isn’t it all part of the performance of the administration of the law in such cases, usually called the main charge, and then another charge in the alternative? Couldn’t the prosecution then proceed with one of the charges whilst they can drop the other one (possibly only putting it on the charge sheet for use as leverage) by offering no evidence on it?
Could it possibly be a legal way of the prosecution hedging their bets whilst they see what shakes loose?
While the prosecution obviously sees evidence of dangerous driving.IE what could possibly account for that discrepancy and inconsistency between them ?.
Only you could see a “discrepancy and inconsistency between them” so I’m wondering whether it could be that there are proper and quite separate legal definitions, criteria and thresholds that go with both charges?
Are you saying that you weren’t aware of the quite proper prosecution practice of adding an alternative charge?
Go on… google them up to discover the differences and prosecution practice in such cases, you know you want to.
… Here’s a multi use present for you…
Multi use because you could use it immediately or you could also use it as an avatar.
</TIC mode>
