cieranc:
Hi Maltese Steve,
When travelling from A to B, I will usually use the most direct route. This saves fuel.
If you were walking from A to B, which route would you take and why?If a weight restriction was put in place, loads would have to be split onto smaller vehicles, meaning more vehicles into the town.
No business in the town will absorb the extra cost of the vehicles, so they will put prices up.
If the delivery is to an end user, the cost of the goods will be marked up accordingly to absorb the extra delivery costs.It appears the issue here is the width of the road. How wide is a standard artic, how wide is a rigid (18/26ton) and how wide is a 7.5 tonner?
Out of curiosity, what sort of vehicle hit the wall you refer to?
Thanks, cieranc.
Well, when walking A to B I would take the most direct route available, unless I considered it unsafe to do so, or perhaps if there were signs advising me that an alternative route would be most suitable for a pedestrian. In short, common sense, rather than “Well, I can go the most direct way and I’m damned well going to, move aside, coming through”.
Don’t know about the widths of the various vehicles you mention, I presume that they’re as near as dammit the same otherwise you probably wouldn’t mention it. Again, the problem with artics is that when they go wrong on that road, the consequences are far more serious than when other vehicles go bad. Their sheer size tends to inflict far greater damage and cause far worse blockages.
If the weight restriction was put in place, then it’s only one road in to Reading. There are many others, all of which are far better routes for heavy goods vehicles, and for the most part just as fast. I don’t see how it follows that HGVs wouldn’t be able to get there at all and deliveries would be split. They’d just go a different way. I’m in no way advocating a ban on HGVs in Reading, I thought I’d made that perfectly clear.
And you know what? I thought it was an artic which hit that wall but I’ll go away and check if I can. I may have heard it on a radio bulletin and there may not be written evidence available regarding the incident. The incident on Reading Bridge, however, was definately an artic and the ensuing chaos caused delays so severe that, trying to get from south Reading to Caversham, I used the M4, J11-J12, A340 to Pangbourne and then Whitchurch Toll Bridge to avoid town. Not many people did though, and town was solid by all accounts. I saw the jams starting at J11 getting off the M4, right up the A33. This kind of thing happens regularly in Reading due to HGV incidents around the Caversham/A4074 route.
