The idea that only ‘vapour’ will ‘burn’ arguably just creates a false sense of security.Realistically given the right ( wrong ) circumstances the fuel,even in it’s pre vapourous liquid state,can be mixed with sufficient oxygen in the atmosphere to burn ( explode ) effectively instantaneously as shown in the video.Which is why the emergency services would require an even more problematic fire fighting operation,in the case of a loaded tanker,than an empty one.In which it’s essential to maintain the integrity of the tank by keeping it cool.Not because they’re bothered about liquid fuel running down the drains but because they know if the tank ruptures the resulting mixture of air and fuel,in whatever state both vapour and liquid,can result in the type of example shown in the video.
Carryfast,
There’s no easy way to say this… your post is wildly inaccurate (= just plain wrong.)
Let’s avoid waffle and words like “arguably” which will allow us to stick to real facts.
The liquid fuel is ONE side of a fire-triangle.
Stated simply, you need THREE things in order for a fire to exist.
So, that’s it… game over.
In the case of a flammable liquid being the fuel side of the triangle, there needs to be exposure to atmosphere in order for evaporation to take place. That evaporation can only take place at a temperature higher than the flashpoint for the flammable liquid concerned. The flashpoints for flammable liquids vary greatly.
Once evaporation has taken place, there needs to be sufficient fuel AND sufficient oxygen, so that the fuel/air mixture is within the flammable range for the flammable liquid concerned. The flammable ranges for flammable liquids vary greatly.
Now that we have a flammable vapour/air mixture within the correct proportions, we now need a sufficiently hot heat source in order for ignition to take place. The heat of ignition needed for the flammable liquid concerned is an important factor. The amount of required heat for ignition of the various flammable liquids varies greatly.
There are four reasons (rules) why a fire involving a flammable liquid may not take place:
1.) The flammable liquid is at a temperature lower than its flashpoint.
2.) There may be insufficient fuel, even if the heat source is hot enough.
3.) There may be insufficient oxygen, even if the heat source is hot enough.
4.) The heat of the ignition source may be insufficient, even if the fuel/air mixture is correct.
There are two kinds of fire:
1.) The kind that you want.
2.) The kind that you don’t want.
Both kinds of fires are subject to rules 1 - 4 above.
There you go Carryfast, no waffle.
