I use similar idea and always give out my own handout to candidates.
Uncouple climb out the cab tell the examiner at this point I am removing my numberplate.
B = Brake (Trailer) Apply the brake
L = Legs Wind down the legs
A = Air Lines Remove airlines and electrical leads
C = Check (Trailer Brake)
K = King Pin
Remove the safety chain and release the 5th wheel coupling.
At this point climb in the cab and pull the vehicle forward under control, separating the tractor from the trailer. Drive forward then reverse the tractor and park by the side of the trailer — climb out of the cab.
Recouple
C = Check (Trailer Brake) Check trailer brake is on and continue around the trailer, checking lights, bodywork, tyres, mudguards and Mot disc.
Climb into cab drive the tractor forwards in front of the trailer and reverse to the trailer stopping just short. Climb out the cab check height of trailer and 5th wheel.
Climb into the cab and reverse under the trailer and listen for 2 clicks. The 5th wheel is engaged. In your lowest gear take 2 big pulls forward to confirm the trailer is hooked. Turn off the engine, climb out the cab.
K = King Pin Replace safety chain
A = Air Lines Replace airlines and electrical leads ( don’t forget to twist the airline collars after connecting ).
L = Legs Wind up legs and stow handle
B = Brake Trailer.Disengage the trailer brake
At this point I am replacing my number plate.
Would you assist me in a light check.
Would you like a rolling brake check.
