newmercman:
In my years of driving I’ve never had any near misses while hooking up, not even with older trailers without spring brakes that often needed chasing around the yard to get hooked up properly. I don’t get it? How has it become so dangerous? You back your unit under the trailer, hear and feel the 5th wheel jaws engage, set parking brake, get out, attach suzies, wind legs up, check tyres, lights, number plate, seal etc and away you go, I can’t see at which point in this process you’re at risk of death or serious injury.
I get what you’re saying, and I don’t completely disagree, I’d be a hypocrite if I did because I did it the exact same way when I started out, but I don’t think people should be knocked for wishing to include an extra safety procedure into their routine either.
At the end of the day what does applying the park brake (if you don’t have an auto engage system) actually cost you the driver? Weigh that up with what not applying it could potentially cost you and I know what I’d rather do tbh.
It’s a bit like saying “I never wore a seat belt for 20+ yrs and never flew through a windscreen, waste of my time and effort putting one on if you ask me” ![]()
newmercman:
Right here unfortunately is where it can all go wrong, the assumption that it’s engaged correctly like it has an umpteenth thousand times before, it only takes a mis-hitch once to kill you or someone else, and the park brake on the unit is not going to do much to help you if the kingpin was actually sat on top of the jaws and then slips off due to the jolt of the trailer brakes releasing when you connect the red line.
Terry T:
Whatever safety measures you put in place you can guarantee an idiot will find a way to make it dangerous again.
That is the sad yet accurate truth.
I’m not a raging H&S nut but I am a fully paid up member of the self preservation society, I have to be, the Wife would kill me if I died and left her with all the bills ![]()
