if you are applying then read the application form a couple of times properly, don’t just skim read it and start writing.
The questions may have changed a bit, but they will ask you what YOU did over and above you normal duties. Anything that states We did they will ignore!
Also they will ask you to state your answers in no more than ### words, COUNT THE WORDS! they certainly will! anything over the stated number will be ignored. you need to get you point over somewhere near to the full amount of works allowed as well.
Get someone else to check you application. A) Are you answering the question asked? B) Is you spelling & grammar OK? C) Is your writing neat & readable?
Make sure that you include anything asked for. This certainly applies to your references, at the next stage in the process after the initial “Papershift” (Done by an outside firm usually") They will contact your references, and ask them to fill out a form that relates to you. (They did want at least one of the references to come from a previous employer, don’t know if that still applies)
Make sure that it is sent in the correct size envelope stated, if they ask for a SAE, don’t forget to enclose one.
Read the application again at lease twice before you send it, I can’t stress enough that you must comply with all the questions and restrictions etc. You will get marked down for anything that you do wrong.
Long experience in your present job doesn’t naturally qualify you, it’s “Life experience” they’re looking for, and how YOU dealt with it. We’ve had 18yr olds and 62 yr old make the grade.
The papershift is normally done by an outside company, they will cut the numbers down to a much depleted amount, so you need to impress! Once the papershift has been completed, the applicants will be invited to an assessment interview, this will be like no other interview that you’ve had, they will throw scenarios at you to see how you’d deal with them, even though you’ve no training, just to test your common sense.
If you pass the assessment, you will be grade by the assessors, the better grades will be offered jobs first, depending on a full security check, and health check. Other who pass will be put on a waiting list, and may be offered jobs should one previously chosen not take up the offer.
