TruckNetUK,Old Times Lorries,Guy Big J Gardner 8LXB Tractive Units.VALKYRIE,Monday,26th June,2017.
There are a number of points that I want to make.And thanks for your kind words by the way.
1.The first is this to TruckNetUK member 5Valve: Quote:-
5Valve » Mon Jun 19, 2017 11:27 pm
Dennis, do you realise this topic has been running seven years! I tried to jog some memories of one or two people who were
responsible for producing engine spec. sheets, at Patricroft, but to no avail, so the 8LXB / Guy saga continues. It is highly
unlikely that we did actually get involved in supplying an 8LXB but it was possible that Guy had it down as an option at some
period.Unquote.
With respect,I’m under the impression that A. you haven’t been on TruckNetUK for quite a while,and therefore B.you haven’t
been keeping up to date with this Guy Big J Gardner 8LXB Tractive Units Thread and C.that you have not read my Guy Big J
Gardner 8LXB Tractive Units Post of Tuesday,13th June,2017. Here it is
viewtopic.php?f=35&t=54395&start=3660
Page 123.
Fourth Post down.
VALKYRIE Quote from my post:-
Total number of Gardner 8LXB 240-250 8-Cylinder Diesel Engines bought by Guy Motors is 57!
NOTE: Guy Motors built at least 29 production Guy Big J4T Gardner 8LXB Tractive Units. Did Guy Motors build more than 29
and/or re-engined Cummins,Rolls-Royce and Gardner 6LXB engined Guy Big J tractive units with those remaining 28 Gardner 8LXB
engines?
Unquote.
2.On reflection,it could well be that Smith of Maddiston (I’ve spelt it right this time
) operated 40 Guy Big J Gardner
8LXB tractive units after all:Most were new,as I’ve already documented,while the rest were re-engined with Gardner 8LXB
engines.
The re-engined Guy Big J tractive units were probably orginally powered by Gardner 6LXB 180 and/or Cummins V6-170 & V6-200 V6
and/or Cummins NHE 180 diesel engines.
The remaining 17 Gardner 8LXB 240-250 Straight Eight Diesel Engines were used to re-engine other Guy Big J tractive units
operated by other road haulage companies.
Don’t forget that the 6-BHP-Per-Ton Rule came in to force in 1972,and all of the above engines,with the exception of the
Cummins V6-200 were on the wrong side of that rule…and those Cummins V6 engines were not that successful anyway.
3.Quote: Gingerfold » Tue Jun 20, 2017 7:39 am
I would make an educated guess that most of the Gardner engines supplied to Leyland were fitted into bus chassis, with London
Transport being a buyer back then.Unquote.
British Leyland Marques And Models That Were Fitted With Gardner Diesel Engines In The 1975-1993 Period.
NOTE:There were of course other engine options in these models.But this is a list of Gardner-engined motor vechicles.
BRISTOL.
1962-1982.RE.Rear horizontal-engined Single Decker Motorcoach & Bus.Gardner 6HLX 150-157,Gardner 6HLXB-180-188.
1968-1981.VRT.Rear-vertical-engined Double Decker Bus & Motorcoach.Gardner 6LX 150-157,Gardner 6LXB-180-188,Gardner 6LXC-193
-201
DAIMLER.
1960-1980.*Fleetline.Rear vertical-engined Double Decker & Single Decker Bus.Gardner 6LX 150-157,Gardner 6LXB-180-188.
NOTE:Sold as the ‘Leyland’ Fleetline from 1974-1980.
*London Transport bought a large fleet of this model in the 1970s,DMS The Londoner,although to be fair,some had Leyland engines.
GUY.
1964-1979.Guy Big J Heavy Lorry-Motor Truck Range:-
Big J4 4x2 Lorry,Gardner 6LX-150-157.
Big J6 6x2 & 6x4 Lorry models,Gardner 6LX-150-157,Gardner 6LXB-180-188.
Big J8 8x2 & 8x4 Lorry models,Gardner 6LXB-180-188.
Big J4T 4x2 Tractive Unit Articulated Lorry models,Gardner 6LXB 180-188,Gardner 8LXB-240-250.
1969-1978.Victory J & Victory J Trambus.Front vertical-engined Single Decker &
Double Decker Bus & Motorcoach models.Gardner 6LX 150-157,Gardner 6LXB-180-188.
1978-1986.Victory II & Victory II Trambus.Front vertical-engined Single Decker
1978-1986.Victory II Series II.Front vertical-engined Double Decker Bus model.Gardner 6LX 150-157,Gardner 6LXB-180-188.
NOTE:These export Guy models were sold under the ‘Leyland’ name from around 1972.
The Guy Motors factory was unfortunately closed in August 1982 and production transferred to Leyland’s Farington factory
at Leyland.
NOTE:-
1954-1962.Guy Arab MkIV.Front-engined heavy-weight Double Decker & Single Decker Bus.
1962-1972.Guy Arab MKV. Front-engined heavy-weight Double Decker & Single Decker Bus.
1950-1959.Guy Arab UF.Underfloor-engined heavy-weight Single Decker Bus & Motorcoach.
1953-1959.Guy Arab LUF.Underfloor-engined medium-weight Single Decker Bus & Motorcoach.
1956-1975.Guy Warrior & Guy Warrior Trambus.Front-engined medium-weight Single Decker Bus & Motorcoach models.
1956-1961.Guy Warrior LUF.underfloor-engined medium-weight Single Decker Bus & Motorcoach.
1956-1969. Guy Victory UF,Guy Victory UF Trambus & Victory UF Airide.Underfloor-engined heavy-weight Single Decker Motorcoach
& Bus models.
These models are not part of this list.But since Guy was such an uphill struggle to research,I’ve made this note because I do
not want to lose this information!!
LEYLAND.
1980-1988.Leyland Constructor-8.Rigid 8X2 & 8X4 Eight-Wheeler Lorry models.Gardner 6LXCT-220-230.
1985-1990.Leyland Lynx MK1.Rear horizontal-engined semi-integral Single Decker Bus.Gardner 6HLXCT-220-230.
1990-1991.Leyland Lynx Mk2.Rear horizontal-engined semi-integral Single Decker Bus.Gardner 6HLXCT-220-230.
1971-1979.Leyland National Mk1.Rear horizontal-engined integral Single Decker Bus.
Leyland 510 Engine from new,but many National Mk1’s have been re-engined with Gardner 6HLXB-180-188,Gardner 6HLXC-193-201 and
Gardner 6HLXCT-220-230 Engines,also Volvo,DAF,Leyland 680 & Cummins engines.
It should also be stated that several motorcoach and bus operators,including Eastern Scottish,Crosville and Eastern Counties
had experimented with Gardner diesel engines in the Leyland National Mk1,prior to it being phased out.
1975-1982.Leyland B21.Semi-integral version of the Leyland National Mk1.Gardner 6HLXB-180-188 engines fitted to some of these
for Ulsterbus and Citybus in 1980.
1979-1985.Leyland National Mk2.Rear horizontal-engined integral Single Decker Bus.Gardner 6HLXB-180-188,Gardner 6HLXC-193-
201,Gardner 6HLXCT-220-230 engine options 1983 to 1985.
1980-1993.Leyland Olympian.Rear vertical-engined Double Decker Bus & Motorcoach models.Gardner 6HLXB-180-188,Gardner 6HLXC-
193-201,Gardner 6HLXCT-220-230,*Gardner 5LXC-170-185 (trial engine),**Gardner LG1200-210-275.
*Leyland Olympian ON5LXCT/1R /Alexander R-Type H45/32F,Gardner 5LXCT-170-185-Diesel-Engined,Double Decker Omnibus-Bus,
B349 LSO.1985. Walter Alexander Northern Bluebird NLO49.
Preserved by the Scottish Vintage Bus Museum,M90 Commerce Park,Lathalmond,Dunfermline,Fife,Scotland,KY12 OSJ:-
Photograph:- google.co.uk/search?q=LEYLAND
+OLYMPIAN,B349+LSO&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiIjMqa49nUAhWkDsAKHflhA-
cQ_AUICCgD&biw=1365&bih=897#imgrc=HlFaEsNH93JxdM:&spf=1498420473441
**A few Gardner LG1200 diesel-engined Leyland Olympian’s were exported to Citybus in Hong Kong,but were eventually re-engined
with Cummins L10 engines.
NOTE:A re-engineered Olympian,powered by a Volvo TD102 Diesel Engine - Cummins L10 optional for a while - was produced
and sold as the Volvo Olympian from 1993 to 1997.
1981-1992.Leyland Tiger.Underfloor-engined heavy-weight Single Decker Motorcoach & Bus models.Gardner 6HLXB-180-188,
Gardner 6HLXC-193-201,Gardner 6HLXCT-220-230.1984-1988.
1978-1984.Leyland Titan.Rear Vertical-engined intergral Double Decker Bus.Gardner 6LXB-180-188,Gardner 6LXC-193-201,
The main customer for this Leyland Titan model was London Transport.
4.The Legendary Gardner Diesel Engine.
The above list shows just how popular Gardner diesel engines were in the British and overseas bus and motorcoach
operating industries.Gardner engines were held in high esteem in the road haulage,bus and motorcoach operating,marine,
railway and industrial engine industries.
As in the road haulage industry,many motorcoach and bus operators were staunch Gardner buyers and fans who bought and
operated Gardner-engined motorcoaches and buses for decades - a great number started buying Gardner engines in the
1930s.
To cut a long story short,the Leyland National Mk1,the standard single decker bus of the NBC, was only available with the
Leyland 510 ‘Headless Wonder’ Engine,and many operators were furious with Leyland and the National Bus Company that there was
no Gardner engine option.
They were even more furious when the 510 engine was found to be suspect and faulty!!
The Bristol VRT became the standard double decker bus of the ghastly and austere National Bus Company,and the Gardner 6LX,6LXB and 6LXC were the standard engines,although some VRT’s were fitted with the Leyland 501 ‘Headless Wonder’,but most
if not all of these,were re-engined with Gardner engines.
From the 1930s the Bristol chassis,Gardner engine combination was a great favourite in the British motorcoach and bus operating industry.There were other combinations such as Daimler,Gardner; Dennis,Gardner; Guy,Gardner; MCW,Gardner ;Seddon,Gardner; and to a lesser extent Atkinson,Gardner; Foden,Gardner; Tilling-Stevens-TSM,Gardner; Gloster-Gardner,Gardner; GNR,Gardner; Neoplan,Gardner and so on.
Although other engines were available in most of these marques,the Gardner engine was the standard engine in most models.
Yes.The Gardner Diesel Engine was as revered in this industry as it was in the road transport industry - even ‘We make it
all ourselves AEC’ fitted Gardner engines in some bus and lorry chasssis…and this later applied,of course, to the Leyland marque as shown in my above list!
Gardner engines were economical in regard to fuel consumption - but that didn’t matter as much to many operators in the motorcoach,bus and lorry operating industries,so they bought AEC,Leyland,Rolls-Royce,Scania,Volvo,Cummins,Mercedes-Benz,Caterpillar,Foden Two Strokes,etc,instead…because they wanted faster and more powerful lorries,buses and motorcoaches.
I’ve said a few times in the Gardner Engines thread that many Gardner engine models were underpowered,and they objectively
were!!
Gardner’s Top Power Automotive Diesel Engines 1931-1994:-
Gardner 6LW - 102 BHP. Grossly underpowered.
To be fair,the standard AEC and Leyland diesel engines of the 1930s-1940s were
underpowered too
…but the AEC A165 Ricardo Indirect Injection 130 BHP Oil-Diesel Engine was promising! 1931.
NOTE:Even the uncompetitive and obsolete Sentinel S4,S6,S8 -Range Steam Lorries were more powerful - 120 BHP!
Gardner 6LWK - 112 BHP. Grossly underpowered.
1950.
Gardner 6LW20 - 120 BHP. Still underpowered.
1968.
Gardner 8LW - 140 BHP. An improvement but still underpowered.
1946.
Gardner 8LWK - 150 BHP.A marginal improvement but still underpowered
.AEC and Leyland 150 BHP engines were also underpowered.
1950.
Gardner 6LX - 150 BHP.Overpraised
,underpowered
and left behind
,introduced in 1958.By 1960 AEC,Leyland,Rolls-Royce,etc were making 190-200 BHP -at least- engines.
Gardner 6LXB - 180 BHP. Still underpowered
,and was still trying to play catch-up with the more powerful AEC,Leyland,Rolls-Royce,Cummins,etc,engines.1966.
Gardner 8LXB-240-250 BHP.A relatively powerful Gardner automotive diesel engine at long last!
1970.
Gardner 8LXC-255-265 BHP.Another relatively powerful Gardner automotive diesel engine
…Gardner was getting there
- but
Gardner was getting left behind again,because Volvo,Cummins,Scania,Rolls-Royce,Mercedes-Benz,etc were making 280-400 BHP + engines in the late 1970s and throughout the 1980s.1978.
Gardner 8LXCT-290-300 BHP.A magnificent and relatively powerful Gardner automotive diesel engine again,introduced in 1981.
Gardner 6LYT-300-350 BHP,with 400 BHP + potential.Gardner finally made an automotive diesel engine powerful enough to match
the likes of Cummins,Caterpillar,Scania,Volvo,Mercedes-Benz,etc.
But alas! Many of these 6LYT engines suffered from quality control problems.1984.Unfortunately this did the Gardner marque
some serious damage to it’s reputation and Gardner never fully recovered.
Furthermore,because of Gardner’s slowness in bringing out the Gardner 6LYT and the less powerful 6LXDT,it lost a lot of customers to the likes of Rolls-Royce-Perkins,Cummins,Caterpillar,Scania,Volvo,etc.
But,for all my criticism of Gardner diesel engines,in their heyday quality-wise,Gardner was the Rolls-Royce of Diesel
Engines.
Gardner is also known as The Showmans Friend: Many showmen have operated Gardner-engined fairground lorries - and ex-
buses & motorcoaches converted to load carriers-caravans - and have employed Gardner-powered electricity generating sets
to power their fairground rides,round stalls,sideshows,etc.
5.There has also been criticism of AEC engines,Foden two stroke engines,Foden motor vehicles and Rolls-Royce diesel
engines on this thread.
But I can correctly answer that all of these generally gave good service to many operators,who were satisfied with
these engines and vehicles and placed repeat orders for these power units and vehicles.
VALKYRIE.
