Evil8Beezle:
1, Wing mirrors, hedges and telegraph poles!
Having driven a week on B roads, I’ve learnt that I have to pretty much play tickle with the hedges using my N/S wing mirror. I’d like to know if it’s like this all year, or is it currently at it’s worst this time of year.
Also, I’d also like to know why the telephone company have a nice row of poles most about 18" back from the kerb, and then a single random pole right on the kerb edge!Be aware that hedges have branches! Your mirrors are your best friend, love them, cherish them, tuck them in and read them a bedtime story because, like your knees, you’ll miss them when they’ve gone!! If you think it’s tight, slow down. Nothing is worth banging a truck. Oh, and beware of overhanging tree branches, the can damage your cab mounted wind deflector.
2, Bridges
Driving under a bridge a few days ago that was supposedly 2" higher than myself, I wondered if the council have a safety margin at all on those marked heights. As I was clenching slightly as I made my way through and looked at all the scrap marks on the underside of the bridge.
Also, On the motorways, you sometimes get concrete bridges that have supports jutting out the banks at an angle, that look like they overhang the hard shoulder. So do you need to be careful of these if you have to use the hard shoulder. (Yes I know, my VAN’s not that high!)
Never, repeat NEVER play roulette with a bridge. If the sign says you’re not gonna make it, you’re probably not gonna make it, why risk it. Considering the grief drivers who hit bridges get on here, I’m surprised people have admitted to going under too low bridges on this thread.
3, Fuel
Is it only HGV services that require you to hand over your fuel card first before you can fill. Or is there some secret code I need to be initiated into while Dipper Dave dances around me bollock naked clutching a blow up sheep & singing a Wurzels track!
Why is my Adblue tank on the opposite side to my fuel?Ad Blue is usually on opposite side to fuel to avoid doing a whoopsie, IMO. Not 100% though. As for fuel cards, if you use a filling station often enough, the staff get used to you and will let you fill up first. Just make sure you have taken your fuel card out with you. Not personal experience, honest.
4, Unsuitable for HGV’s
What exactly do they mean by that? As it doesn’t say “NO HGV’s”, so does it means; Be my guest Mr HGV, lets see you make a ■■■ of yourself! Or is a notice to discourage use of this route? As so far, I’ve bottled it when I’ve seen that sign, and reassessed my route to target. And in a couple of cases i’ve return that load to the yards saying that they need to send the 7.5t to do that drop. And if your wondering, my justification was that i didn’t want to bash the truck up, and they seemed happy with that, and if it was perfectly normal.Unless I absolutely have to, I avoid these routes. There are a couple of rural routes near me with this sign. I’ve cycled down them and really wouldn’t like to take an LGV there. If possible, eyeball them first or ask a local.
5, 7.5 ton weight limit signs
Why is it that as you approach a weight restriction, the first signs to it say just that, and only the last one before the limited area do you get the sign that says “except for access”
On one occasion I ignored the first 2 signs on the way to a drop, as I could see it was a long way around to use any other route on the SatNav map. Also i could see there was a railway line, so when i didn’t see a low bridge sign with the weight limit sign, i assumed it would be an issue. So anyway, when i got to the last weight limit sign that said “except for access” I found also a low bridge sign, and by then I could see the bloody thing!If you KNOW you’ll get away with it, go for it. You probably won’t get away with it though. IMO not worth the risk of driving past these signs (unless the drop is in the restricted zone of course).
6, Securing loads with a strap system like this.
For a start, what’s it called?
Next, would you really strap every load, or just the items you think might be an issue?
(Obviously the pic looks like an ADR load, so probably it should have the crap strapped out of it!)
As a lot of my deliveries I’ve not strapped, and when i have, it’s been the lighter and taller pallets. But the issue isn’t the load moving side to side, it’s falling forwards, and I’m not that impressed with putting a diagonal strap across the front of the load. It didn’t save a stupidly tall collection I made and then met a nutter on a roundabout.As I had to shove the anchors on when he changed his mind, and the first thing i though of was that pallet (well only after swearing to myself) And when I opened the curtain back at the depot, I had a pallet to restack!
- But at the same time, the client was taking the ■■■■ with paying for “1 pallet” of transport, as the pallet was the height of my wagon minus 2 inches!
So any tips about this system? i.e. When and how…It’s tricky with multidrop because route order tends to dictate loading. As you found out, stuff tends to move forwards (as you brake) more than anything else. If in doubt, strap the crap out of it. Undoing straps is quicker than reloading or handballing a pallet of stock.
7, Taking control of the loading
At the place I’ve been for 3 days last week (which I really enjoy, and they want to tell me about their perm package!) I’ve always been loaded and then told my truck is ready. But Thursday I had 2 runs to do, and was back ready to be reloaded at lunchtime. And this time the forklift driver said I was to tell him the order and placement of the loads.
Well that was my expression at the time, but after the initial shock, it occured to me that this is the way I’d want it! And I shouldn’t rely on the forkies to think about how positioning will affect my drive, or using one load to support another under breaking. So should I be more assertive next week and try to get involved in the morning loading? I’m not saying take charge to start with, just watch and ensure it’s to my liking!
A decent forkie will know what they’re doing. Talk to them and ask them why they are loading it how they are. Get hints and tips off them, and other drivers too. Get yourself a bank of knowledge so when you don’t have a decent forkie, you can recognise it and get them to do it right. Oh, and be gentle with them, most forkies are sensitive souls.
I think I better stop there, and thanks for any help!
Oh, forgot to say, wear sunscreen. You’ll still get your badge of honour (drivers arm) but it wont hurt as much!
