speedcamerasuk.com/gatso.htm
read it
Gatso Speed Cameras
There are over 4,000 fixed Gatso speed cameras currently in use by police forces and local authorities across the UK, accounting for 90% of all fixed speed cameras. The Gatso which uses radar technology, is used for fixed speed cameras, in-car mobile units, on tripods and can even be used from moving vehicles.
. Unfortunately, this also means the cameras are not always viewable until the last second (as pictured above). The cost of installing a Gatso speed camera is approximately £20,000, but can cost as much as £40,000 if located in a rural location, as the system requires a 240v power supply.
The fixed Gatso camera has the ability to take up to 400 pictures. Cameras in that are located in busy areas or are particularly hidden, often only last a few hours before the film runs out, soon recouping the £20,000-£40,000 price tag.
Gatso speed cameras can also identify between cars/vans and HGVs separately. For example, if the speed limit was 60mph for cars/vans and 40mph for HGVs the camera will enforce the two separate limits.
It is common for fixed Gatsos to be positioned so they can be turned around to check both sides of the road - but only one direction at a time.
On the M25 in Berkshire and Surrey Gatso speed cameras have been placed in gantries across the width of the motorway with all four lanes covered simultaneously.
Points and Penalties
Being prosecuted in the UK by a Gatso speed camera can result in a minimum of 3 penalty points and a £60 fine. Fine amounts are currently under review by the government and may increase in near future.
note about
Fixed Gatso speed cameras are rear facing. This is so the cameras ‘flash’ does not blind oncoming motorists
and
